Check your filter cycles and switch spa into Standard Mode as you have it in Economy. (In Economy mode it will only heat during the filter cycles).
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Posted on Apr 17, 2013
SOURCE: Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on May 20, 2011
SOURCE: I have a whirlpool duet front load washer and the
you have a bad water valve on the washer.sediment gets into the valve,when the valve goes to close it can't from sediment inside it.change out the valve and you'll be fine.
Posted on May 23, 2011
SOURCE: doesn't spin fast enough to
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Posted on Aug 12, 2011
SOURCE: Washer does not add enough hot water
He is right, we can thank the energy mandate for than. In all new washers they are only required to reach 69 degree. All detergent are now activated at 62 degree no matter what. Some washers do get hotter but not lg
Posted on Dec 06, 2012
Jun 09, 2017 | Water Heaters
Jan 01, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
May 02, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Mar 13, 2013 | Balboa Instruments Pool & Spa
Dec 23, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
May 06, 2011 | 2007 Chevrolet HHR Special Edition
May 05, 2011 | Heating & Cooling
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Sep 23, 2008 | GE Washing Machines
Mar 04, 2021 | Hoover Washing Machines
139 people viewed this question
