Cleaned printer heads and printed test page. All colors good except magenta?
It appears the magenta print head nozzles are blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
SOURCE: Printer will not use cyan
Well I just bought a brand new Kodak 8500 and purchased a few boxes of the 25 1400 print kits after getting it I thought it would be as easy as the Kodak Easyshare 4x6 printers BUT thought different after trying my first box of 25. I got 10 good prints out of 25 due to paper jams after 2 passes. I did the alcohol thing on the LED and sensor and that worked good for 1 full box of 25.
I then loaded a box of 50 8500 ribbon and paper same problem more paper jams after 2 passes wasting more $$$.
I did the whole routine as stated above and after taking the whole darn thing apart I did 1 more mod. I turned the potentiomter 1/2 of a turn but then drilled a small 1/2 hole in the forward plate where that pot is and reamed it out to over 3/4 on and inch thus if you need to make further adjustments you do not have to take the whole thing apart again, just the lower front cover. Because when the front cover is removed with the 5 screws and not 4 the whole darn circuit board falls out and its hard to get the plastic protective strips covering the top and bottom to align back up to slide it back in place. SO with the hole drilled there you do not have to bother with that ever again. After doing the les than 1/4 of a turn I still had a problem and yes I did put it all back together,
BUT at this point I removed the lower front cover and had access
to the pot again and moved it another 1/4 of an inch clockwise installed the 2 screws tried again and I ran a whole box of 50 without a problem.
I don't know if I'll have anymore problems but If I do I'll post it.
SOURCE: Kodak Easyshare 5100 Wont Print In Color Or Black
For all of those problems, you need to replace the Printhead. This is one of the most common issues among the Kodak All in One Printers, they simply stop printing text. However, it seems that Kodak is sending out some new printheads that work so much better, so you should get in contact with their support and have them replace their printheads. Call 1-800-421-6699.
This sort of thing is usually due to dust/dirt on the sensor that detects the gaps in the dye-sub film. Half of the sensor pair is in cover that flips up to replace the ribbon, the other half is under the plastic bar. I clean them with a dry Q-tip or blow them off with canned air.
