Turn off your Canon 1000D and
remove the memory card, lens, battery and time/date secondary battery.
The secondary battery is a small, round battery about the size of a dime
found in the same compartment as the main battery. It is located in a
vertical slot. Slide out the secondary battery by pressing your finger
on the battery and pulling it toward you.
Place the body cap on your
camera to keep dust out. Attach the front and back lens caps on your
lens to prevent scratches and other damage.
Let the camera sit for 20 minutes. This will clear the camera's memory.
Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
Press the shutter release button
(the button you push to take a picture). If you are still receiving an
Error 99, the problem is most likely caused by the camera body itself.
The camera body must be serviced by a professional camera technician.
Turn off the camera and insert
the memory card. Turn the camera back on and press the shutter release
button. If you are receiving an Error 99, the error is most likely
caused by the memory card. Turn off your camera and insert a different
again.
Turn off the camera and reattach
the lens. Turn on the camera and press the shutter release button. If
you receive an Error 99, turn the camera off and remove the lens.
Turn the camera so that it is
face down, and gently clean the lens contacts on the camera body with a
number 2 pencil eraser or soft cloth. The lens contacts are the eight
small, gold pieces on the bottom of the lens mount. Be careful not to
let any of the eraser scraps fall into the camera body.
Turn the lens so that the side
that attaches to the camera is upside down. Use the eraser or soft cloth
to clean the lens contacts on the lens, being careful not to let any
eraser scraps fall into the lens.
Reattach the lens to the camera.
Turn on the camera and press the shutter release button. If you are
receiving an Error 99, the error is most likely caused by the lens. Take
the lens to a professional camera technician for repair.
6
again.
Went
to the beach yesterday, by the end of the night my camera gave me this
error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down) 2. Gently tap the sides of the camera (to loosen particles in lens) 3. Turn camera on 4. The lens will eventually come out 5. Gently tap the sides of the lens 6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Lens of the Camera doesn't retract: ---------------------------------------
Before trying any of the suggestions, make sure that the Battery is
fully charged and in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,
then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed
air (20 lbs) set the tip between the lens turret and the camera body
and turn on the air while moving the tip around the lens. It should
remove all dust and sand. Turn the camera on and it should function
fine.s
3) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and
take a look at the spacing between the lens and the lens housing. If
you notice that the gap is not even all the way around the lens, the
problem should be easy to fix. This type of a problem usually occurs if
the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try
powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts
again, do the following.
(a) Turn the camera off.
(b) Take the camera in one hand and with the other gently take one part
of the lens and gently move it round in a circular movement. Do so with
both sections of the lens. You will hear a "click" as it pops back in
place.
(c) Power the camera on.
Another version of this fix would be to pull and twist on the largest
ring of the lens while turning the camera on. Listen for a "click". If
at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start
improving.
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned. Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal. More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Same problem guys!!! LENS HAD GOT STUCK - ABOUT ONE THIRD OUT after a knock. After lots of playing, and tapping and batteries in and out tried the whole twisting and pulling thing whilst turning off and on.
After a few minutes it came free and whole lens popped out. I then had to twist the outer part of the lens to straighten that up and allow it to fully retract. Works a treat now!
PS Tried the Sony online chat support - useless!!!!
