Cell Phones Logo
izzy Posted on Apr 05, 2013
Have a Samsung galaxy tab 2 , 7.0" ...3113 .....4.1.1 want to root need to know what to down load to my pc and how to due it..thanks
James Coble
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 13, 2016
James Coble
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
601
Points
Thanks @Nash..Will it work for my galaxy tab 2? Just to make sure.
Brack Coco
Level 1:
Habit-Forming:
New Friend:
  • Contributor 11 Answers
  • Posted on Mar 03, 2016
Brack Coco
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
11
Questions
0
Helped
11087
Points
67
There are 2 Iroot version for you to choose.You can follow these instructions to root it.
http://www.iroot.com/how-to-articles/root-samsung-galaxy-tab.html
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Apr 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
3676
Points
33
Step 1:
1. The following procedure works for Samsung Galaxy Tab 2 P3113 smartphones.
2. Make sure your device have at least 80% battery power.
3. Make sure USB Debugging is enabled
Step 2:
1. CF-Auto-Root to root P3113UECLK7 firmware [Filename: CF-Auto-Root-espressowifi-espressowifiue-gtp3113.zip]
2. Odin 3.07 [Filename: Odin307.zip]
Step 3:
1. Extract Firmware zip file and you will get a .tar file and some other files.
2. Extract Odin zip file and you will get Odin3 v3.07.exe along with few other files.
3. Switch off your Galaxy Tab 2 P3113
4. Now, put the Galaxy Tab 2 P3113 in Download Mode by pressing and holding the Volume Down key and Power button.
5. Then, a warning message appears, press the Volume Up key to continue.
6. Now run Odin3 v3.07.exe as an Administrator because Admin privileges is required to complete the process smoothly.
7. Now connect your Galaxy Tab 2 P3113 with your PC using USB cable.
8. Then a message will arrive under Odin's message box in the bottom left saying "Added!!"
9. Select these files in Odin at respective tabs from extracted firmware folder:
  • Click the PDA Button, and select the CF-Auto-Root-espressowifi-espressowifiue-gtp3113.tar.md5 file.
10. In Odin window, make sure Auto Reboot and F. Reset Time checkboxes are selected. Also, make sure that Re-Partition checkbox is selected, only if you are using a .pit file.
11. Double check everything that we mentioned in Step 9 & Step 10 above. Now, once satisfied hit the START button to begin the flashing process.
12. Once flashing completed, you will see a PASS message with green background in the left-most box at the very top of the Odin. The tablet will then automatically rebooted and soon you will see the Samsung logo. You can then unplug the USB cable to disconnect your device from computer.
Congrats! Your Samsung Galaxy Tab 2 P3113 running P3113UECLK7 Android 4.1.1 Jelly Bean firmware is now rooted. You can now install apps that require root permission.
5 Related Answers
Anonymous
  • 38 Answers
  • Posted on Jun 05, 2011
SOURCE: Just got your Sansung
sir
welcome to fixya
you can find all about yor mobile phone in this site web
download this book and read it and i hope to find what you need
addition if you need more explain you can asked me in any time and any problem you welcome
Anonymous
  • 1010 Answers
  • Posted on Jan 25, 2011
SOURCE: samsung galaxy tab - how
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
nashsaint
Nash delos Santos
  • 172 Answers
  • Posted on May 05, 2011
SOURCE: Need to do driver install
you need to download Samsung Kies software. This will install the necessary driver and the application suite.
hope this helps.
David Lee
  • 422 Answers
  • Posted on Jun 30, 2011
SOURCE: galaxy tab choppy music and
possibly too many apps running in the background.
try rebooting it and play
also, install appkiller to clean the memory then try again to play.
Anonymous
  • Posted on Oct 24, 2012
SOURCE: download root
why this mobile not go long time in charge ?
1helpful
3answers
How do I jailbreak my galaxy S4 without erasing all the data?
hi this is how to ROOT not Jailbreak your galaxy s4
First of all there is no jailbreak for android but there is root
and to root your device you can first backup your data on your pc
then search on google for towlroot install it then open it then click on make it rain and it will root your phone
but if it doesn't work or your phone is not supported then you have to root from your pc I will provide you a link to download root for s4 on pc
How to Root Your Samsung Galaxy S4 Or Almost Any Other Android Phone In...
Hey i rooted my android tab and its never been the same its stuck on android 3.0.1 can this be fixed?
Rooting a device always has the potential to turn the device into a 'brick' in some circumstances. Most good rooting procedures mention this, as well as steps to make a backup of the current system and how to recover from a failure to boot after rooting. There are also different 'mods' that can be tried to see if one of them will work in place of the one you first chose for rooting. These are all dependent on exactly how Android was modified for your hardware. Google 'rooting' and 'Samsung Galaxy Tab 101 Tablet GTP7510MAyXAR' and see what the articles say. You can also try a hard reset of your tablet and see if that does anything. Example at this link http://forums.androidcentral.com/samsung-galaxy-tab-pro-10-1-rooting-roms-hacks/396031-how-root-your-galaxy-tab-pro-10-1-a.html
How to Delete samples frm samsung galaxy tab 3
if by samples you mean apps you dont want, go to settings, more, application manager, slide to all, look down list to app you want to delete and select it. If you want to remove it hit the disable button and OK to anything following. This disables the app and it wont appear or work until enabled. You cant fully delete anything without root access which basically allows you to do anything including screw up your device, so its not normally provided.
2answers
How to root galaxy III
Too many steps to write here. Do a Google search, "root g3" or related. Here's a link to get you started: http://gs3.wonderhowto.com/how-to/easiest-one-click-root-method-for-your-samsung-galaxy-s3-0155625/
4helpful
4answers
How to install a game on my samsung galaxy tab?
Well, there is a place called "Android Market" or similar.
If your desired game can be found there, simply download and install the game app and you can enjoy the fun.
If the game can't be found, or it requires a fee to play. You'll probably need to root the device. Here is a 1-click Android-Root solution for your reference.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
