Question about Mitsubishi Televison & Video
WD 65732 replaced lamp lasted 6 months replaced again (blew out with air hose did not take back off) lasted 46 days replaced lasted 16 days lasted 10 sec. took back off very dirty. is ballast bad or just dirty
Posted by jcaudle330 on
Sonny Berry
  • Mitsubishi Master
  • 8,617 Answers
It sounds like the ballast may very well be whats causing the lamps to fail. I would try replacing tha ballast.
Posted on Apr 06, 2013
John Hickock
    New Friend:
    Problem Solver:
  • 4 Answers
Replace the lamp thermal sensor. It keeps the fan running (after the set is turned off) until the bulb has cooled down. It's a un top of thesmall cream colored rectangular piece with a short lead wire comming out of one end. It's on top of the air tunnlel lamp housing.
Posted on Jan 02, 2014
5 Related Answers
Anonymous
  • 150 Answers
SOURCE: How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Posted on Aug 01, 2007
Anonymous
SOURCE: WD-52525 Lamp failed 2x in 4 months..is it the Lamp?
Having the same problem with the dim picture on my WD-52525. Had the lamp replaced and still had a dim picture. My authorized dealer has been in contact with Mitsubishi Tech Support and they are thinking it's the optical engine (light engine).
If you think the replacement lamps are expensive, wait till you see the price of the optical engine. My dealer told me they run around $750.00! If this is the problem, I'm hoping they will cover it under warranty as the TV is less than 2 years old.
Posted on Feb 01, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Mitsubishe wd-65732. Air flow problem.
There is an access panel on the side of the television the air filter is behind that panel with the air vents
Posted on May 04, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Posted on Sep 04, 2008
Anonymous
SOURCE: Need to replace ballast on mitsubishi wd-62526
I replaced my own the part cost $109,it was somewhat time consuming since taking the back panel off was a learn as I went.However I still didn't get the red LED to go off.....TV still would not power up in it's normal fashion.Previously I had 2 lamps burn out,and you definetly could tell they burned out.Since then I have changed the power supply feeding($130) the ballast circuit and I still haven't got the TV to come on without defaulting to the red LED,and taking the chasis apart to do this was a real pain.I have posted a question about my problem recently.Still waiting for a solution.Mitsubishi won't sell a customer any parts........they want you to go to atechnician that works on their product.GOOD LUCK!
Posted on Jan 07, 2009
I have a 2006 WD 65732.just replaced the lamp,still have white haze around,pepole and words.could it be a seal?
Quite possibly the lens is in need of a clean. It sounds like it is acting a bit like when you see a moon on a night with high cloud, we see a ring around it caused by the atmosphere, much the same as dust on the lens.
Hope that helps.
Dec 31, 2010 | Mitsubishi WD-65732 65" Projection HDTV
My tv keeps shutting down when I turn on. The message on the the TV screen said that "the TV will be shutting down in a few minutes". I resit the lamp in the back of the TV and the TV works after I reset...
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem.
It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design.
Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831.
As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
Nov 30, 2017 | Mitsubishi WD-57732 Projection Television
WD-65732 has audio but no picture. Sound like
Replace Lamp Call Mats Electronics 1-800-628-1118
Mar 25, 2010 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Oct 24, 2009 | Mitsubishi WD-73736 Television
I have a wd-65732 dlp mits projection tv its a 2007 yr ive had to put 3 lamps in it and 2 other friend have the same tv and same problem whats up?????
MOST LAMPS IN THESE SETS LAST APPROXIMATELY A YEAR TO A YEAR AND A HALF MAYBE YOU SHOULD CALL MITSUBISHI AND TELL THEM ABOUT YOUR PROBLEM.
Aug 09, 2009 | Televison & Video
Just replaced the lamp on my mitsubishi wd-65732 2 months ago and now have no picture and i just the red lamp light on. please help
if you used an OEM lamp rather than an original ,it may have gone out. The more expensive original bulbs last longer
Jun 07, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
467 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
