Question about Ranger Radio Communications
Rci 2970 blown fuse - Ranger Radio Communications
Mike Charette
    Genius:
  • Ranger Master
  • 1,847 Answers
Open the fuse holder in the back of the radio get the number off it. It will probably be a 5 amp fuse but whatever ,replace it with the same one.
Posted on Feb 23, 2015
2 Related Answers
Anonymous
  • 16 Answers
SOURCE: RCI 2970 squeels until you unplug the external speaker and plug i
Strange! I used to run almost the same kinda setup but with a super scanner omnibeam, i modded mine myself. At 1 time i had a squeal problem it was in the mic if i remember correctlly i ran a external wire from the screw on the spring inside the mic where the cord comes out to the radio chassis and it stopped it give it a try. I used a simple speaker wire, also you might want to try grounding the radio to the power supply. Sounds like a ground problem! I have a awsome mod for that radio that would enable you to run a regular amp with it and also would enable you to talk local without engaging the amp in the radio using only 4 watts! Let me know how it works out for you with the squeal? if intrested in that mod contact via email at ([email protected]). put 2970 in the subject line. Take care.
Posted on Jan 19, 2009
anymhz
AnyMHz.com
  • 500 Answers
SOURCE: RCI 2970
broken coax inside the radio going to the amp.. is the display ok? sometimes static from storms will knock out the processor and the radios will quit. have to replace the cb shop temple, tx on yahoo search processor board. to restore operation on that problem. is there more info can help us with?
Posted on Dec 08, 2009
No power to radio
its called a reverse polarity diode,its black and near the electrical wires that come into set.
May 06, 2014 | Ranger RCI-6900F-150 CB Radio
How to change a memory battery in an RCI 2970
its the round dime sized battery on the back of the cpu inside (back of faceplate) there is an battery upgrade. www.cbtricks.com
Feb 10, 2014 | Ranger Communications RCI-6900F-25 CB...
Audio in my rci 2970 has no punch to the audio
cut back on the power,turn up the modulation and you should be good.
Dec 25, 2012 | Ranger Radio Communications
Need operating instructions for RCI-6300F150
You can download and print the operating manual for your 10-meter transceiver here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_om.pdf
In case you need it, you can also download and print the service manual here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_sm.pdf
Bill B.
Oct 25, 2010 | Ranger RCI-6300F-150 Base Scanner
RCI 2970
May 06, 2009 | Ranger RCI-6900F-150 CB Radio
Jan 17, 2009 | Radio Communications
Replaced RCI Cell 2 times, light still doesn't come on
The U.V light is inside the RCI cell. If you replace the RCI, it has been ok. Please don't mind the screen display.
Oct 09, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest FreshAir - UV Flickering
UV bulbs, or rather the RCI cell needs to be changed every three years in the FreshAir, or when the "Replace RCI cell" appears, whichever comes first. The UV bulb loses its intensity over this period of time.
Eric
Download PDF Manual
Feb 17, 2008 | Ecoquest Fresh Air Air Purifier
Radio Communications Logo
82 people viewed this question
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
