Is there a setting for plush carpets on a dyson ball dc 41 vaccuum cleaner?
Hi there, it's Jack at Dyson.
DC41 Animal's cleaner head is designed to self-adjust to different floor types - so you don't need to bend down to adjust a dial. You can see how this feature works in the video below. In addition to this, next to the red on/off switch you'll see a silver brush control switch, which allows you to turn off the brush bar for hard floors and delicate carpeting.
Carpet manufacturers sometimes recommend vacuuming certain types of carpeting with the brush bar turned off - we'd suggest checking directly with the manufacturer of your carpets to ensure you're cleaning them correctly.
If you'd like any further advice on using your DC41 Animal, please email us at [email protected] and one of our experts will be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
SOURCE: dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
SOURCE: The carpet brush on my
Next to the power switch is another button, this switches the brushbar on and off. The brushbar can be turned off for hard floor surfaces so as not to scratch them
SOURCE: Right out of the box,
I found the fix for the dc 33. Open up the cover to the beater bar. look at the cover. You will see many small triangles. Look very closely for a small rubber strip that runs along the edge where the triangles are. It is kinda hard to see. Once you find it remove it. Now on the vacuum itself there is another strip. This strip is very similar but a little longer. Remove that strip. No more **** noise whalla. The perfect Dyson!
SOURCE: My dyson vacumn is hard to push on carpeting. How do i fix it?
my dyson dc17 animal had become nearly impossible to push on carpets. I
did some research and somewhere on this forum i saw that someone
mentioned replacing the roller.
sure enough i found that my roller was warn down to nubs (vacuum is probably 8 years old, and gets used nearly every day)
I replaced the roller and WOW! it feels like its self propelled now. HUGE DIFFERENCE.
thanks for the help!!
