Question about Bialetti Mukka Express
Bialetti Mukka Express - red light flashing/beeping
My Bialetti coffee maker worked fine until this morning. I prepared it and turned it on, and after a few minutes, the base indicator light started flashing red and beeping. At that point the base is warm, but not hot enough to push the water up. I checked the gasket by flushing water through it and it's clear. After each use I rinse the coffee out of the filter and so that's clear as well. What is the cause of this flashing/beeping?
Posted by Patrick de Man on
  • Patrick de Man Apr 05, 2013
    Ok, never mind. in my absentmindedness this morning i forgot to put water in the base. So the red flashing/beeping is probably a overheating warning. Too bad they don't list that in the manual or on the Bialetti website under problemshooting.
  • Bruce Leimsidor
    Bruce Leimsidor Dec 27, 2014
    I have the same problem, and I have put water in the base.
3 Related Answers
Anonymous
SOURCE: Cleaning problems
Hi - I just clean mine with hot water (no soap), and dry it with a towel then leave it on the window sill... My problem is that the coffee can taste a bit metallic at times; and i want to know if I should be cleaning it after every time I use it... Suggestions?
Posted on Jun 23, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: coffee has started becoming weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
Anonymous
SOURCE: bialetti mukka express
First off, the best milk for foam is skim milk (0% fat). The higher the fat content, the less foamy your foam will be.
The foam is created by the steam/hot coffee from the lower part being forced through the doohickey and into the milk. That means that if the coffee itself isn't "perfect", the foam won't be "perfect". I've found that using different types of coffee (e.g. different grinds) or filling the coffee bin to different levels results in more or less steam/pressure being passed through, so the foam is better/worse. For example, if I put too much ground coffee in the bin or use too fine a grind, it blocks the water/steam that's going through the coffee, resulting in less coffee and weaker coffee, and also resulting in less foam.
Posted on Jun 04, 2009
Are there any tools in USA to open electrical base?
if it has screws then there will tools to remove them
find a good tool shop and there will selections of driver bits that will fit any screw made
take the base along to try the fit of the blades.
Muka express bialetti leaking
Easy!! Not making coffee or cappuccino, go to Starbucks less issues LOL
I cannot unscrew the top of the Mukka Express machine from the bottom!
If the bottom is screwed too tight on the top, you could try to warm the with hot water and cool the bottom with cold. This could help to expand the top and make it easier to unscrew.
2helpful
I was looking for instructions for a Bialetti Mukka Express ;and also does this unit make espresso?
Here is the owner's manual. Also, by filling the filter with espresso grounds and using water, you are making espresso. It only becomes cappuccino by adding milk.
http://www.google.com/url?sa=t&source=web&cd=5&ved=0CEcQFjAE&url=http%3A%2F%2Ffantes.com%2Fmanuals%2Fmukka_express_manual.pdf&rct=j&q=Bialetti%20%22Mukka%20Express%22%20owners%20manual&ei=JdWATp7uLcu4tge7prWNAQ&usg=AFQjCNEIi9J9flq7TmgLWUYOiLF4KatH3g&sig2=UqfzIzEfVCpfZv60t1wClg
2answers
2helpful
I cannot unscrew the top...i have waited until cool and taken out the pressure valve...it still wont unscrew! help !!
dip the top part upside down in warm water, make sure the bottom doesnt warm up, the material from the top will expand and comes loose from the bottom, it might need powerfull hands anyway good look
7helpful
Bialetti mukka express
Espresso irregularly spurts out the center post
could it be that the gasket is oversized and it covers the small holes ?
1helpful
Mukka Express spits out coffe from the screw section & steam valv
it did that to me too, so I reduced the amount of milk to the indicated level inside. No more mess after that.
Mukka valve broke
HAVE YOU TRIED SYDNEY?
Bialetti Mukka Express Logo
Top Bialetti Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
