When computer is turned on resuming windows displays,then setup is starting services displays repeatily wont do nothing else
I found a solution for the same problem that fixed it for a few people. Try this:
1) On the same error screen press SHIFT+F10 and it will open up a black Window. (a command prompt window) 2) In the black windows type the word "regedit"(without
the inverted commas and hit enter. That will open the registry editor.
In the Registry Editor.. Browse to.... HKLocal
machine/SYSTEM/SETUP/STATUS/ChildCompletion, and after highliting
childcompletion,on the right hand side check for setup.exe. if the value is 1 change it to 3.(by double clicking on setup.exe and changing the value shown in the box). Then close the registry editor and then also close the black window.
Then click on OK for the error and the computer will restart and the
installation may complete. just try it and let me know if it worked.
I found this solution at http://www.tomshardware.com/forum/69394-35-acer-aspire-wont-setup-starting-services-help
Let me know if this helps,
Thanks!
SOURCE: acer travelmate 2420
Hello! :)
The first thing I would have you do is to shutdown the computer (Hold the power button until the system turns off) and retry the format. Are you using a Microsoft XP disc or a recovery disc? If your not sure just post with all of the text that appears on the CD.
