If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replacedIf the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
God bless you
Testimonial: "Thanks Ernesto. It turned out the connection to the wax motor was loose. I reconnected it and it's working :)."
SOURCE: detergent dispenser doesnt open
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
SOURCE: maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
SOURCE: Dishwasher detergent door spring
I ordered and received the new Bosch dishwasher detergent door, but do not know how to repalce it!
SOURCE: detergent stays in the dispenser
Clean and dry your dispenser prior to filling with detergent.
Use only fresh detergent.
Do not place anything ie. cookie sheets, cutting boards in the path of the water obstructing the dispenser.
Do not allow anything to fall between the racks and stop the spray arms from turning.
Always turn the hot water on at the sink prior to starting you dishwasher they use less than 2 gallonsof water in the initial cycle and they require 120 deg f water. Unless you have hot water recirculation in your home.
If you have low water volume or low water pressure due to bad impellor or windings in circulation pump. The water volume or pressure will be insuficient to reach the dispenser.
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Sorry, I meant EX600
Problem solved - the electrical connection to the wax motor was lose. I took off the cover the front of the machine, reconnected the cables and all's good.
... I meant the wax motor was loose...
