Lost the instalation paper when we moved anyone have a copy or know where to get one
SOURCE: Lost installation CD
Doesn't that use Activesync? http://www.microsoft.com/windowsmobile/activesync/default.mspx USB driver is at http://www.mio-tech.be/en/support/168-downloads.php Hope that helps. Good luck
SOURCE: installing a car alarm instructions
I can provide you with a wire diagram that gives you color, description and location of the wires in the vehicle. Is that what you want? As far as brand, did you have one in mind? The wire printout would have to be e-mailed to you as I can not post it here due to the size of the words (too many). Let me know.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: spy car alarm manual
Forget the advice on how to steal a car. It's pointless and does nothing to answer your question. I suppose alicantecoli is proud of his abilities (I used to be too, but I don't do that anymore), however he is a fool if he thinks a 2-Way alarm is useless. While it may only take him minutes to disarm the alarm (waaaaay too long), with a 2-Way system & GPS tracking it would only take me seconds to find it again. Or you could use the silent alarm feature, allow the car to be stolen and immobilise it in the middle of the road. Beside all of this, a simple set of relays properly wired to monitor the alarm system power status can turn those few minutes into an hour or two. Anyway, to your question.
The install manual for the (rebranded) Spy 2-Way Car Alarm is a pathetic chinglish translation printed on a single sheet. It would do you no good unless you have some experience with electronics, and a working knowledge of your car's wiring. That being said, here's the wire colours for you:
6-Pin Connector:
Purple : A/C
Brown: On
Yellow: Start
Red: 12v+
Black: 12v-
12-Pin Connector:
Central Locking - it depends on the type as to how you wire it...
Yellow: Nc
Y/Black: No
White: Com
W/Black: Com
Orange: Nc
O/Black: No
Brown: Flash Lights
Brown2: Flash Lights
R/Black: Trunk/boot release
Red: Siren
8-Pin Connector:
Red: Window roll-up
Green: Side-door + trigger
Blue: Side-door - trigger
Yellow: Engine cut-off
White: Acc
Orange: Foot-brake
Purple: Handbrake
Grey: Start-sensing
2-Pin White: LED
2-Pin Black: Temp. Sens.
3-Pin White: Shock Sens.
3-Pin Black: Microwave Sens.
These four plug in in this order: 2PW, 3PB, 2PB, 3PW
Inside the unit (under the sliding cover on the top) there are three jumper settings: Elec/Pneu CL, Lights Flash/No Flash, Auto-arm/No auto. The first of each pair is the default setting.
Hope this helps. That, honestly, should be all you need. If you do need more info, then please DO NOT TRY TO INSTALL THIS ITEM YOURSELF. As it says on the manual, "Install the system by a professional people."
Well, I cannot help you with a disk, but I can offer this insight:
Seems this scanner only works with USB2 ports, and if you only have USB1 ports, you will not have any luck.
Additionally, while I cannot help you with drivers, I have found others who say that Windows XP (and it is assumed Vista) does not need drivers to operate this scanner.
Simply go to the Control Panel, (after it's plugged in to a USB2) and click on Scanners and Cameras. The operating system will guide you through a wizard which will allow you to scan images into your computer.
Once there, however, you are sort of on your own to choose the software you want to edit those images.
good luck
tony
