Question about Kenmore Vacuums
I have purchased a replacement belt at local Sears. Salesman could not remove foot cover and I can't figure it out either. There are no visable screws or latches, etc., to remove the plastic cover on the bottom of the beater bar foot. I bought this 25 yrs ago and no longer have manual...
Squeeze in on each side of the cover with the headlight lense to remove it. There are two screws under the cover you will need to remove. Then flip the power nozzle over and insert a screwdriver between the base and top cover on the left and right sides to release the catch to remove the top cover to get to the belt.
Posted on Feb 11, 2018
SOURCE: powermate plastic bottom broke
Go to www.sears.com, click on parts, the part you need is:
BASE-NOZLE
8191779 (4370725)
11650812007
$ 33.09
$ 33.09
You can order it thru sears online. Cost is $33.09, plus tax and shipping.
Posted on Jan 10, 2008
SOURCE: Kenmore Quick Clean Advanced Allegen
Go to Sears.com, click on parts, put in your model number, a parts list is available, also a picture diagram of it. You can purchase what you need from this site.
Posted on Mar 06, 2008
SOURCE: beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Posted on Mar 08, 2009
SOURCE: Flair S2220 Removed the four screws holding bottom
Pop out the two little rollers underneath, at the front. you will find two little screws holding it on. Unfortunately, I found after I broke it off!
Posted on Jan 16, 2010
SOURCE: sears progression kenmore canister va. Model
Hi.
The part is probably available as replacement.
Please click here to access part list and diagrams, and check if the part is available.
Regards.
Posted on Mar 03, 2010
