SOURCE: settings for a new watch
http://www.adidas.com/campaigns/watches_fw07/content/index.asp?strCountry_adidascom=us&strBrand_adidascom=performance
check it here.. you will surely be able to solve it as i have just done...
press top left and it will say HOLD for setting.. so hold it... then choose one step after the other with the left bottom.. and increase with right top and decrease with right bottom.. rest you can find in the manual at the website... good luck...
SOURCE: Annoying Beep on Adidas Watch
try holding down one or more of the buttons at once, you should hear a short beep indicating that the beep is off
SOURCE: I dont know how to change the date/time for my adidas watch.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ADIDAS watch manuals. Rate me, please .
SOURCE: cant set digital time and date on my adidas 10-0140 watch
click this link for instructions
http://www.adidas.com/campaigns/watches_fw07/content/performance/pdf/performance_en.pdf
I have the Adidas ADH4018 and I assume the controls are the same, unfortunately, Adidas has absolutely no manual online for this watch. I've figured out how to do most of the functions of this watch.
NOTE: For greater setting accuracy, I recommend using a stylus-like object or the retracted tip of a retractable pen (as to not write on your watch) to click the number keys when setting the time and date for the first time.
Set the Time:
To set the time go into time mode by pressing the lower silver button on the right side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 7 to change the hour, press the number 8 to change the minutes, press the number 9 to start the seconds over at 00. Press the multiplication key (x) to change from 12 hour to 24 hour time modes. When finished press the time mode key.
Set the Date:
To set the date go to time mode by pressing the lower silver button on the left side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 4 to change the month number. Press the number 5 to change the day of the month. Press the number 6 to change the day of the week (indicated by a small dot above the days of the week abbreviations at the bottom of the digital display. When finished, press the time mode key.
Set the Alarm:
To set the alarm time, enter alarm mode by pressing the upper silver button on the right side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 7 to change the hour, press the number 8 to change the minutes. When finished press the time mode key.
Turn the Alarm On or Off:
To turn the alarm on or off, first enter alarm mode by pressing the upper silver button on the right side of the watch face. Then press the divide key (÷) to change from on to off or off to on. When the alarm is ON an indicator icon will appear in the upper right of the display in time, date, or alarm mode. When alarm is OFF there will be no indicator icon displayed.
To Use the Calculator Function:
Enter Calculator mode by pressing the Clear All (AC) key on the keypad when in time mode. Use the number keys and function keys to complete calculations. To return to time mode simply press the time mode key.
As of yet I have not discovered how to turn off the annoying beep when you press any button.
