SOURCE: broken m2 card
Try to put the memory card into the card reader of any system. If nothing comes, your memory card has some problem and is better to get it replaced.
Thank You
SOURCE: m2 memory card needs formated
insert into your computer, Go to my computer and right click on your memory card. go down to format.
SOURCE: My c902 has suddenly stopped recognising the m2 card
This may have something to do with how the m2 card is formated. PC systems such as FAT32 and NTFS do not work with cameras or telephones as the data cards in these devices are formatted to FAT16 or lower. In order to read the card when you placed it in your PC FAT32 would have been used.
If you are prepared to loose the data on the card I suggest you use a PC to re-format it to FAT16, your phone should then recognise it again!
SOURCE: Computer does not recognize the M2 micro memory stick san disk
1. It means your computer is not able to access your phone!
2. Memory card seems to be working properly!
3. Try to reinstall the phone driver software on your computer.
4. Restart the system and check again!
please rate this advice if it helps...tc! :)
SOURCE: i did a reformat but still my phone cannot detect the memory card
1. If your memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
4. You should replace that memory card with a compatible one!
