Question about Astoria Gloria SAE Espresso Machine
Flashing lights on my Astoria Gloria SAE 2, also missing the key on the front
We have bought a used Astoria Gloria SAE 2 Espresso Machine, we are missing the key on the front( the programmer key), & today all the lights on the front started flashing, can anyone help with this & does anyone know where i can get a programmer key from ? Regards John
Posted by John Marsh on
5 Related Answers
Anonymous
SOURCE: Astoria SAE-2
yes i found ur probelm . this might happen because of coffee deposites in the porta filter.
remove the screens with the help of the screw driver and wash it throughly .
then fix it again .
if still it is not working then , call me i will help u out .
ROhit PAtil
india
9766678617
Posted on Dec 30, 2008
EsWorld
Ernest R
  • 1618 Answers
SOURCE: cannot turn off flashing lights on buttons to start espresso
The keypad needs to be programed. Depending on your model there will be a small toggle switch on the right side, just behind the connection of the hot water valve(you will have to remove the top panel). Move the switch to the left, then press the program button at which time all the lights will be lit. Using a measuring cup press a button you want to program until you get the desired amount, then press the stop button(when programed the light will turn off), repeat to program the other 3 buttons. When done program move the toggle switch to the right. If the machine does not hold the program then the flowmeter under the drain tray(silver box with 3 wires on top), is damaged. Either repalce the top or check the impeller in the flowmeter, the magnets might dirty.(Make sure water is turned off before openning the flowmeter.
Posted on May 28, 2009
Anonymous
  • 22 Answers
SOURCE: need manual/schematics for espresso machine.
Your coffee supplier will be able to provide you with one.
www.kaldi.com
Posted on Jul 16, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: how do I program an astoria SAE-2 espresso
Look behind the right steam valve, you will have to remove the front top panel, there might be a small toggle switch, note the position. If switch is not there then it is on the black CPU box. Press the program/stop button if all lights come on move forward if not then move the toggle switch to opposite side and press program button.
When all four lights are on press a button when you get the desired volume press stop, continue until buttons are programed then move toggle back to original lock position.
Posted on Sep 29, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: our coffee shop is closing
Get the price for a new one and cut the price of yours by 1/3 or 1/2.
Posted on Mar 14, 2011
Model number is SAE/2XL and I need a owners operating manual. we bought a used machine but they don't have a manual so,we want to know how the machine works and how to clean the machine. thank you if...
Could you please post the full model number and if you happen to have the serial number as well of your Astoria Argenta SAE-2 Espresso Machine? Thank you I await your reply
Rick
Blinking lights in Astoria sae
Water is not flowing through the flowmeters. It could be a blockage in the line or the wheel is damaged or the flowmeter head is damaged. But the blinking lights indicate a water flow problem.
Gloria two group Astoria was shooting steam the other morning we turned it off what could this be from?
Where is the steam coming from, if its from the top, then the problem is the vent valve or the safety valve, if it is the safety then the pressure stat needs to be replaced because it might be damaged or blocked at the tube that connects it to the boiler.
We have an astoria model SAE.2 for some reasen the machine has gone very quiet and appears to be strugling when re charging after each use
It sounds like the water pump is not doing its thing or the machine cannot get water, either blocked filter or water line.
2answers
I have bought a used Astoria sae Espresso Machine and I need to know how to clean it - can you help?
You'll want to back flush the machine with espresso machine cleaning powder:
http://www.kaldi.com/cafe_supplies.htm and regenerate the water softener regularly.
7helpful
How do I program an astoria SAE-2 espresso machine?
2helpful
Astoria SAE 2 Programing
The key is that you have to HOLD the programming button in for about 5 seconds before the system will go into programming mode. All the lights will come on and you will know you are ready to program the various shot buttons.
Astoria Gloria SAE Espresso Machine Logo
Top Astoria Coffee Makers & Espresso Machines Experts
NOEL
NOEL
ADMIN Canada
ADMIN Canada
Kolbrun...
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
