Question about Pioneer DEH-P47DH CD Player
The illumination had worked intermittently for a while, then not at all on my Pioneer DEH-P47PH receiver. Can the faceplate be repaired or replaced?
It seemed that the contacts from the detachable faceplate to the receiver were not secure, so tapping or moving the faceplate would sometimes make proper contact for the illumination to work, but only temporarily. No other functions are affected, so I'm wondering if bulbs or LEDs could be lose inside the faceplate.
6ya staff
SOURCE:
Anonymous
  • 148 Answers
SOURCE: Screen behind faceplate stopped illuminating/working
The ribbon cable has gone bad. A new one can be ordered direct from pioneer at parts.pioneerelectronics.com Good luck!
Posted on Nov 05, 2006
Anonymous
SOURCE: can pioneer faceplates interchange?
no i wouldnt do it i put my 980bt on a 8600? and now both cd player displays are fucked they dont display anything but they still play cds
Posted on Jul 17, 2008
Anonymous
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
e-bay
Posted on Feb 02, 2009
kenw392
kenw392
  • 2226 Answers
SOURCE: Pioneer deh-p8600 Motorized face not functioning
it probably has a bad flexible cable.
Posted on Jul 29, 2009
apollosarmy
  • 4 Answers
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
Posted on Aug 16, 2009
I have a pioneer deh p4400 detachable faceplate does not seem to close tight enough goes blank when you touch it lightly press on it and works fine I have cleaned contacts what else
Did you clean the contacts on both the face and the sub-panel? What did you use to clean the contacts with? Sometimes cleaning the contacts with a pencil eraser will work a little better.
Dec 31, 2012 | Car Audio & Video
My Alpine CDE 7872 faceplate goes blank intermittently, the unit still functions, just can't see what station you are on, what track, volume, etc...
is the faceplate detachable? if so remove it and clean the metal contacts on both the din unit itself and the faceplate with rubbing alcohol on a cotton swab or Q tip.
if it is not a detachable face, then i would say an internal solder joint is starting to come loose, that is an older alpine model number after all.
Dec 16, 2009 | Alpine CDE-7872 CD Player
Can't detach faceplate
You should have a button to push on the corners. If not look back in the manual for " how to detach face plate".
May 24, 2009 | Car Audio & Video
Faceplate won't close
Alot, of the radios have a common problem with the connection from the radio's2.gif detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD2.gif and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, the display partially turning on and off, and the face to act peculiar and flip down halfway. In addition, sometimes the face open and close switches go bad, but I've never had to replace them yet. .
Dec 15, 2007 | Kenwood KDC -X815
Faceplate
Mine did the same thing, send the whole thing back.
Nov 25, 2007 | Phase Linear UMP8015 CD Player/Receiver...
Faceplate
Push the button in the bottom right corner. if this seems to not be working then there may be an issue with mechanism that release the face from the main part of the radio.
Oct 13, 2007 | Pioneer DEH-P2000 CD Player
Detaching faceplate on dual stereo XD 7500
Got to the following lik for your manual: http://www.dualav.com/i/product/manual/xd7500.pdf Refrence page 6 for instructions. With the unit off, press open to allow the front panel to slide down. Genetly squeeze the release tab located on the bottom center underside and pull faceplate down and away from unit to remove. To install insert left side faceplate first then push right side to secure. Hope this Helps L8R
Sep 18, 2007 | Dual XD-7500 CD Player
Pioneer DEH-P47DH CD Player Logo
26 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
