Vacuums Logo
A
Anonymous Posted on Apr 04, 2013
Riccar vacuum 8625 problems
.service manual
Looking for a parts list / manual to replace the motor
You will need to purchase the motor from a Riccar dealer. If you don't have a local dealer contact me at [email protected]
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Riccar 8625 doesn't seem to beat carpet but the brush is turning
Your 8625 is well over 20 years old. If it's been over a year since you've replaced the belt start with a new belt. Belts lose elasticity and should be replaced at least once or twice per year. The brush roll will still spin and appear to be working fine but when you put the brush roll onto the carpet it will stop spinning fast enough to clean the carpets.
How to install belt on Riccar 8750 commerical vacume cleaner?
No. There is only one belt. Remove the bottom plate to gain access to the belt.
Riccar model 8625 need compatible repalcement motor for original Ametek # 117405-00 12 amp no longer available ?
You can likely get any 8000 series motor to fit but there are different motors and you really need to talk to a qualified trained Riccar repair technician to determine the proper motor for your model. Your model is almost 30 years old and a newer motor would be difficult for the average homeowner to safely install. You were given good advice because they told you to discuss it with a qualified retailer for the proper way to safely get your vacuum running again. If done properly there could be many more years of usable service left I your old vacuum. If done wrong it could cause damage to the motor or other parts of the vacuum or even cause a fire, death or injury.
How do I replace the belt on my ricaar model 8750 vacuum?
Remove the bottom plate to access the brush roll. Remove the brush roll to install a new belt. Your
model is over 20 years old. If it has never been Professionally serviced it may be wise to take it to a Riccar dealer for service. It could add many more years of life to your vacuum.
What type of bag does it use
This uses a Riccar 8000 series bag, or a Simplicity type B bag.
I have a Riccar 8750, when I plug it in any outlet and turn on the headlight does not come on and the vacuum does not turn on. The reset button does not seem to help. It worked fine when I shut it off last...
An 8750 is likely at least 20 years old but still may have lots of life left. I still have 8600 series Riccar vacuums brought in to my vacuum shop for service. You may have a loose wire, bad switch or power cord. I would take it to my local Riccar dealer to diagnose and repair.
1helpful
NEED ASSISTANCE ON INSTALLING BELT FOR MODEL 8625
HI There,
Here's a link that will walk you through step by step on how to replace the belt on your Riccar 8625 upright. This is an almost identical model, and the belt change is identical to yours.
If you have any questions please feel free to add a comment on the repair, and I"ll be happy to follow up and answer any of your questions.
Please rate my repair or send me feedback if this helped you,
http://www.fixya.com/support/t4184186-replace_belt_riccar
Thanks,
3helpful
3answers
Riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
