I need a replacement TV remote - Televison & Video
Posted by Jane Newsom on
Sonny Berry
  • 8,617 Answers
Just send a email to [email protected] and let them know the model numberof the TV that you need the remote for.
Posted on Apr 05, 2013
GVA remote has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 10, 2012 | Televison & Video
My remote isnt working
Regards.
Jan 04, 2012 | RCA F27676BC TV
T.V. remote sensor not working
Hello
If you are sure that the fault is with the remote sensor of your TV, replace it with a new one. The remote sensor can be located just behind the remote sensor window at the front panel of the TV. You nave to open the TV to access it. It is a three solder terminal component. It will look somewhat like this, having brownish black in colour. This component can be bought from most of the electronic spare part selling shopw at your town; very cheap to buy too. OK
Nov 28, 2011 | Televison & Video
My remote wont work on my grundig gu15wdt/gu15wdpcx, have tried changing the batteries and it still doesnt work, where can i get a new one?
Lastly, please don't by a remote with confirming it is a remote problem. You have to be sure before thinking of a battery replacement.
Regards.
Jun 09, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
My remote will not work the tv anymore
there are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Yours sincerely
Elect_Comp.
May 12, 2011 | Televison & Video
Will not work...batteries changed and no response
I believe you are referring to the remote control of your TV.
Good luck.
Apr 02, 2011 | Televison & Video
KLV37U-300A Sony BRAVIA Flatscreen TV. TV does not respond to its remote. Remote sends signals (when remote aimed at digital cam I can see the lights go on). Believe sensor on TV not recognizing remote...
Good luck.
Feb 24, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
