SOURCE: k image drum
Go to
menu>Configure Device>Print Quality>select Full calibrate now
once it's completed then run following action:
Menu>Configure Device>Reset>Reset Supplies>New transfer kit>yes
you are done but it works if there still remaining bit transfer kit if its run out then not gonna work.
Good luck and rate all answers.
SOURCE: How do I replace the image drum(s) in the OKI
you're going to have to buy a new one. Unfortunatelly you can't replace just the drum. There are "after-market" drums for some OKI's so you might want to look into that.
SOURCE: resetting image drum after replacing for oki b4600
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
