Question about Hotpoint First Edition WMA20 Front Load Washer
Wma20: water gushes out of dispenser drawer instead of going into drum
WMA20 has worked perfectly for 20 years then suddenly (after a stay by a very stupid house guest) water gushes out of the dispenser drawer instead of going into the drum. My laundry room is flooded and the washing does not get clean. Is there a blockage caused by non-emptied pockets? If so, where should I look as the most likely place to be blocked. Thanks!
Our Hotpoint WMA20 Washing machine is not draining, even though it appears to do a fast spin. The machine was installed several years ago and has previously worked normally. Is there likely to be a...
Filter is tbe found by removing lower rear cover of washer, and removing the large black hose fastened to bottom of drum, remove and clean plastic filter inside the hose.
Aug 24, 2010 | Hotpoint First Edition WMA20 Front Load...
Can you tell me where the brushes are located in a Hotpoint First Edition WMA 20 please
Removed lower rear panel of washer.
Undo 2 screws securing motor to outer drum casing, unplug motor lead and remove motor, brushes ar e located at the end of the motor furthest away from the motor pulley.
Aug 06, 2010 | Hotpoint First Edition WMA20 Front Load...
Stinky grey goo in my Hotpoint WMA20 washing machine
you can only change the seal as this is a common fault with low tep washing Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Oct 28, 2009 | Hotpoint First Edition WMA20 Front Load...
Fabric compartment is always full of water
you have to remove the soap drawer complete and view above where it slides in. you will see several holes where the water sprays out these holes get blocked, you will need to get a washing up brush invert it and scrub these holes as clear as possible (pay particular attention to the ones above the fab cond slot). this may need to be done at least once a month, also the soap tray will need to be stripped and cleaned also.
Mar 16, 2009 | Hotpoint First Edition WMA20 Front Load...
How to remove hot water inlet valve
In ost cases there is a scerw on the outide of the machine which holds the bracket that holds the valve. Go ahead and get the valve and look over the new one, it will tell you volumes about how to install it. Like where that screw would be, Good Luck!
Mar 12, 2009 | Hotpoint First Edition WMA20 Front Load...
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint WMA20 First Edition
your bearings have gone and inturn your drum has droped which has cut heater so it has gone 2 earth which is y your electric has triped the whole job should nt cost more than £120 that is what i charge any way 4 a new inner and outer drum supply and fit good luck
Sep 08, 2007 | Hotpoint First Edition WMA20 Front Load...
Hotpoint First Edition WMA20 Front Load Washer Logo
54 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
