Question about Avantco Refrigeration Refrigerators
How to set temp dial on Avantco SCLM2 48" Mega Sandwich / Salad Prep Refrigerator
5 Related Answers
Anonymous
SOURCE: Broken Sandwich prep thingywhatzit
bad thermostat
Posted on Dec 06, 2007
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: turbo air sandwich table too cold
Replace the thermostat which is located on the back of the unit underneath the bins in the very back. If the thermostat goes bad it will let everything just run and run and run. If this has been helpful please rate
Posted on Feb 12, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: The refrigerator is freezing everything, even when temp is adjust
Leads me to believe the thermostat is not working. See if you can find the model number located on the bottom frame near floor behind fresh food section door and I will be able to help you better, Thanks, Sea Breeze
Posted on Mar 21, 2009
Randy Justice
  • 80 Answers
SOURCE: sandwich prep refrigerator too warm.
It sounds as though you have a clogged capillary tube, cannot be sure without suction and liquid line pressures and temps but if you can, ask the tech if the suction pressure seemed to be low, if so, replace the capillary tube with the proper length and diameter tube, replace the liquid line dryer and pull a GOOD vacuum on the system and recharge it, refering to the rating plate for the proper amount and type of refrigerant.
Posted on Jun 23, 2009
Dennis Boxerman
  • 1303 Answers
SOURCE: I got a true refrigeration sandwich prep table it ...
Look for doors not properly closing, poor air flow over coil or something blocking air flow, improper freon level.
http://www.truemfg.com/pdf/InstallManuals/TPP_TSSU_TUC_TWT/tuc_english.pdf
check out this web site as it has a manual for your equipment. it has lots of good info. Hope this helps. If you need more help, let me know.
Posted on Jun 13, 2010
True prep table leaking water.
The drain tube that drains out the water is plugged. It runs from inside the cabinet to under the refrigeration unit outside the cabinet. Try to clean it out with a can of compressed air used to clean keyboards and see of that works.
Sep 19, 2016 | True TSSU-48-12 - 48 Sandwich Salad Prep...
Adjust true prep table door
There are plastic cams in the hinges that wear and are replaceable. A company called Case Parts supplies a lot of refrigeration hardware like that and the web site should help and another company is called Refrigeration Hardware. The parts breakdown will show you what I mean. Hope this helps and good luck.
Oct 10, 2014 | True TSSU-48-12D-4-ADA 49" ADA Compliant...
Metalfrio prep table freezing evapoator
Check that all vent areas are clear of any dust or food packaging. If you have ice build up it needs to be thawed out also because it will only continue freezing until it gets proper airflow.
Sep 17, 2014 | Metalfrio SCL2-60-16 Salad Sandwich Prep...
I got a true refrigeration sandwich prep table it will get down to temp. But as soon as it gets down to about 38 it will start frosting up all the way back to the compressor and by the next day it has...
May 19, 2010 | True 598-TSSU608ADA SandwichSalad Unit 155...
Sandwich prep refrigerator too warm.
Jun 22, 2009 | Fogel FOG-FLP4512 Undercounter Sandwich...
Salad prep cooler too cold I turn the t-stat up or down compressor still running I think the t-stat is bad don't you think?
It sounds like the thermostat is "stuck closed". Try unplugging the cooler, MAKE SURE ALL POWER HAS BEEN DISCONECTED. Remove thermostat cover with thermostat on it. Carefully pull one of the wires spade connectors off the thermostat. Insulate the end of the wire you disconected with electrical tape. Now plug the cooler back in. If the compressor stays off the thermostat is the problem. Let me know if that helps. I know of a common replacement cold controll for that unit:)
Apr 05, 2009 | True Refrigeration Mega Top Sandwich Salad...
Turbo air sandwich table too cold
Feb 12, 2009 | Turboair Turbo Air Sandwich Salad Table...
Refrigerators Logo
Top Avantco Refrigeration Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
Are you an Avantco Refrigeration Refrigerator Expert? Answer questions, earn points and help others
