Palm Zire 71 Handheld Logo
Question about Palm Zire 71 Handheld
How to recover data from a crashed zire 71
Pda crashed is all data lost
4 Related Answers
Anonymous
  • 473 Answers
SOURCE: Zire 71 Power probelems
it is wise to try a to reset ur zire while it is on charge...otherwise I suggest u to send it for repair again. best of luck.
Posted on Sep 12, 2005
Anonymous
  • 12 Answers
SOURCE: lost data on palm zire 21 hand held
To the best of my knowledge, if you don't have a pc backup, you are out of luck.... Sorry to be the bearer of bad news... Download the Palm Desktop Software and start to use it if you decide to continue using the Zire 21. The Software is free from Palm.
Posted on Sep 26, 2007
Anonymous
  • 164 Answers
SOURCE: Palm Zire 71
The top plastic digitizer is defective.
It needs to be replaced.
There are several sources on-line to buy such digitizer part.
Best regards,
Posted on Jul 25, 2009
Anonymous
  • 164 Answers
SOURCE: Need Palm Zire 71 Software
Exactly what software are you looking for?
Despite you have no software CD, you can get in PalmOne web site, and in the support and download section, you can download all the basic and need applications and software for it.
Best regards,
1helpful
My computer suddenly lost all the data for the palmone zire 72s. Can't figure out why. Don't want to sync in case it deletes all the data from the pda.
Hello.
First, install Desktop Manager on another computer and sync, just as a backup.
Then, before you sync on YOUR desktop, look for the option on the Desktop Manager to copy from the PDA to the desktop only, so you won't lose your data.
Then, after the sync, change the Desktop Manager back to 2-way sync.
Hope this helps.
Hope this helsp.
1helpful
Palm zire 71
Install Documents to go software...a version comes with the intial CD. It can also be purchased on line through Dataviz.com..the best software for reading officefiles on a PDA
Palm Zire 71 handheld does not come on, did a hard reset, nothing
Confirm that both the cradle and the PDA ports are clean and free of dust or dirty.
Also, check your AC wall adapter to confirm that is working. The output should be +5.0 volts DC. Any repair shop has a multimeter need it to check it in no time.
If everything appears is OK, then confirm the PDA is properly placed in the cradle, and that the PDA is not loose on the cradle, indicating that the port contacts are not touching.
Best regards,
The information on my Palm Zire 71 all appears to have been lost.
looks like it's completely gone, hope you kept backups.
was the data stored on the SD-Card, if so try putting the sd-card in a computer/card reader.
Zire 71 Camera
1) The camera is most likely broken- unless you are handy dont bother trying to use the camera
2) The booklet isn't all that useful but you can find a copy of it on Palm's website as a PDF file
3) It will turn off and a prompt will warn you of the low battery, but if you continue to turn it on it will "forget" everything in memory
I hope this helps and I hope you enjoy your Zire - it is a good PDA
Palm zire 71 replaced battery camera and charging port not wrking
Dis you see if either the brown plastic locking part of the connector is broken or missing?
Do you know if the soldering joints and terminals of such connector are in good shape?
I am asking because it may be only that the flat ribbon cable is nort placed properly, or such flat ribbon cable is damaged.
Also, the connector at the mainboard can be damaged.
Depending of what is damaged, it will be the cost to repair it.
I do recoomend you to disassembly very carefully your pda again, and check such areas and parts.
If you find something that is broken, you can get the needed parts from a broken PDA in Ebay or similar sites.
Best regards,
No display
Hello LyMaBa
Do you have an SD card inserted in the PDA?
If so remove it and restart your PDA.
Did the problem go away. If so, please, go HERE for the Zire 71 Expansion update or HERE for the SD/SDIO update.
You can find all the manuals for the Palm Zire 71 PDA HERE.
If you don't have a SD card inserted, you might want to try performing a WARM RESET of your PDA. Youtube has a video on this process HERE.
You can find instructions HERE for performing a reset ("warm" or "hard") on your Palm PDA.
You can find other software, info, downloads, etc.
HERE for your Zire 71.
If performing a "warm" reset doesn't work, try performing a "hard" reset.
*** WARNING!!! ***
YOU WILL loose ALL of your data on the PDA by performing a "hard" reset so make sure it's data has been synchronized w/ your computer software (Palm Desktop, Microsoft Outlook, etc).
* If the information I provided you w/
* resolved your problem or lead you
* to a resolution for your problem or
* an answer to your question, then, a
* "FixYa" rating would be most
* appreciated. @:)
* (You can assign the same rating to
* more than one expert who participated
* in solving your problem.)
* It is best to wait until the problem
* has been resolved b4 rating the experts'
* solution(s). Once you enter a rating,
* the problem will be closed and we will
* not be able to continue to assist you.
* Very often it will take more than one
* exchange of information between you
* and an expert in order to resolve your
* problem. If a proposed solution doesn't
* work for you, don't rate it yet. Instead,
* post back here letting us know and we'll
* continue to work w/ you until we find a
* solution that does work for you.
* Thank you
* BJ @:)
My palm zire 71 does not ever synchronise to mi laptop
You can check in PalmOne web site the user manual for such PDA.
There are all the instructions in how a synchorinzation is done, and how to add new applications to it.
Best regards,
2answers
Palm Zire 71 Display Problem
If you slide your Zire up as if you are using the camera, there is a reset hole in the back that you can poke a needle or pin into to have it do a "reboot" which will not lose data.
Not sure why the display changed.
Open Questions:
Top Palm Computers & Internet Experts
Muzahura Frank
Marvin
Marvin
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
