I need to allow more than 1 network connection at a time and I forgot where the option was location and which utility it was located in. I am not running control point that came stock with the system, I am running only the Dell wireless switch utility. The 2 connections I need to run are a wireless internet connection which is already functioning properly alone and an ethernet connection to high powered digital recognition cameras which function properly until connecting to wireless internet which is frequired for the software that I am running.
SOURCE: Dell Latitude E5400 running XP; wireless
Try to use a 3rd party software: NetSetMan.
You can set 5 different types of ip's and dns. Just enter them first and after that just activate one set. And the soft automatically changes the system settings.
Here is the link: http://www.netsetman.com/index.php?s=nsm
Just scrool down and press download.
If you need further assistance, leave a comment.
Thank you for using FixYa
SOURCE: Dell Latitude E5400 internet connection problems
If you are not using it, uninstall Dell Control Point Connection manager, then the Window Wireless configuration will function normally
SOURCE: dell E5400 connecting to projector, "presentation
Check your keyboard for a "Fn" button and a picture of a screen or similar on another key, usually in the same colour as the "Fn" is written in which will also be a different colour to whatever the normal keys are in.
If you find them, hold Fn down and then tap the key that looks like a screen (might be F8)
If that doesnt do it, look in your system tray (icons by the clock bottom right) for a display menu, right click on it and go through looking for dual display options, play around there - I cant give you steps because I dont know what you will have there but it should be apparent what to do when you see it.
