Question about Nokia mobile C2-00 Dual SIMbiosis
Nokia c2-00 .restarted when calling
My nokia c2-00 mobile restarted when i calling . why
Mehtab ali
    New Friend:
Nokia C2-00 celling to restat phone
Posted on Aug 04, 2014
My Nokia c2-00 shows "Contacts not ready" message after I turned it on. I can't see received calls, missed calls, dialled calls & contacts list. I can make a dial call, but I can't get receive...
i have faced the same problem in my Nokia c2-00 and i did the following and problem solved.
1. switch off the mobile.
2. Remove the battery.
3. Remove the sim cards & memory card from the slots and reinsert it one by one.
4. restart the mobile. Now i can view the contacts and msg's in my phone..!!
Mar 29, 2012 | Nokia mobile C2-00 Dual SIMbiosis
My cell c5-00 now from yesterday problem that mobile itself restart within 2-2 min...and like problem that listening music the song run 2 min then itself mobile restart so not doing any work also call same...
There is Software Problem of your mobile or There may be virus attack on your mobile so it is getting restart after 2 min. You should renew your mobile software if your a technician the use the dongle box to renew your software like JAF Software Dongle or UFS software Dongle using this you can renew you mobile software if you are using any other software dongle's then you can use that to renew your mobile software.
After doing this if problem does not solve then there is hardware problem in your mobile please check the battery connector, power amplifier, Power IC & Boot IC. while doing this your mobile will get damaged so do it very carefully if your mobile go dead then we are not responsible for that.
If your are not then Please visit your nearest Nokia Service Center (Nokia Care) or Visit any Mobile Repair Center they will solve your problem in a day.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jul 01, 2011 | Nokia C5 Cell Phone
Mobile softwear virus attack. mobile virus scaning is ok but no work. now mobile 5 min. after automatically restart. and mobile IME code is fault
This is a guide how to reset your phone to factory setting eliminating all problems/viruses.
C.O.D.E 1: --->>*#7370#
C.O.D.E 2: --->>
STEP: 1. Switch off your Nokia Mobile,
STEP: 2. Press-> Call button, press-> 3, press-> *,
STEP: 3. Now Switch on your Mobile.
Mar 06, 2011 | Nokia 7210
My mobile (model: nokia 1650) restarts when I try to set the ringtone. My phone is now in silent mode and does not ring or vibrate for any incoming calls. Could you please provide a solution for the same....
you want to goto settings in your mobile phone and select restore factory setting, in that type the security code 12345 and press ok .then the problem will be solved
Dec 30, 2010 | Nokia 1650 Cell Phone
My nokia e65 has no display but can accept call
my mobile lcd dnt display anything , but i sound is cmeing , when i use mobile or play mius. but it doesnt display anything
Oct 31, 2009 | Nokia e65 Cellular Phone
My nokia n70 handset restarts automatically ..also it has the hanging problem ,i have to remove the battery and then insert by that time also it starts without pressing the start switch .while it is kept...
Hai,
I am sure that you mobile is effected with virus, I request you to format the phone.
Here is the steps to format the Nokia N 70 mobile.
Before formating the phone please take the backup of the contacts and messages.
Turn off the mobile.
Press and hold call button + star button + number 3 and turn on the mobile and wait until you see time settings.
This should fix the issue.
Oct 15, 2009 | Nokia N70 Cellular Phone
Cant call out on 6630 nokia
sampurna
just u restart ur mobil, then u can call.
Jul 15, 2009 | Nokia 6630 Handheld
Nokia 5630 restarts when attending calls+Voice recorder to memory cards not works
connect ur mobile using data cable and make a full format and then u restart ur mobile.
Jul 06, 2009 | Nokia 5630 XpressMusic Smartphone
Not getting call register
if important contacts & message in your mobile then copy first.to solve this problem you hv to done restore factry setting using the code *# 7370# then confermation message willbe displayed select yes there after mobile restart automatically.
Aug 24, 2008 | Nokia N72 Cellular Phone
Cell Phones Logo
572 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
