I would say that you need a new charger. Standard chargers that come with digital cameras will eventually deteriorate depending on how often you use it. However, it could also be a battery issue, as batteries eventually will die even if they are rechargeable. I would try the charger with a different battery and see if it works, and if not, then you will know that the problem is with the charger.
most chargers will fuction on 240/50 hz, look closely at the writing on the charger, it may say. I have laptop chargers and have used the overseas with no problem, that being said, you might try contacting dewalt and asking them if you can do it. Like I said, it probably already will work without doing anything. i have seen some devices (amplifiers mostly) that have a switch on the bakc to switch voltage, ( I don't recall ever seeing a switch to change line frequecny though), hope this helps a bit
If you are in India, you can check out here to buy elinchrom studio light product in ArihantDigi.com. Its the website for shop lights for your studios.
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
A new product laptop battery charger AC input:100-240V AC50/60HZ DC input:12-24V High output:16.8V2.5ADC Lowoutput:12.6V2.5ADC charge time:3-5h color:black size:1.7*62*30mm That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery. That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge,any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples. It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience . If you have need the product, please contact us Mobile:13751018213 skype:lincen18213 Email:[email protected] FAX:86-755-61573100
Yes, the battery that comes with the C-7000 can be recharged. This battery is the Olympus LI-12B Lithium Ion battery and it can be recharged using the LI-10C battery charger. Both the battery and charger are included with the camera.
