My projector 52' Rca tv model # p46731AT wont turn on, when i hit the power button on the tv it clicks the light comes on for about 2 seconds then powers RIGHT back off...PLEASE HELP
  • 8,617 Answers
Check the Flyback Transformer and Hot. especially if its a soft ticking sound
Posted on Apr 04, 2013
6ya staff
SOURCE:
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: tv wont turn on, RCA D56w20, 56" rear prjection
replace the flyback 259296 and the CP150 capacitor. You can get the replacement parts with free instructions at the following link.
http://servicemanuals.vstore.ca/
Posted on May 17, 2009
Anonymous
SOURCE: RCA HD61W66 Turns on then cuts off I NEED SOME HELP
Ive had a similar model since 2002 and it had the same problem. Factory power supply to weak for the model. Mine was replaced twice before the upgrade came out. Sorry, I dont think it is a $.50 solution.
Posted on Jun 19, 2008
Bill England
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
Anonymous
  • 5 Answers
SOURCE: My rca tv d52w17 won't turn on.
Sounds like a faulty power inverter to me.
If it's covered under warranty, take it back to where you got it and ask them to cover the warranty for you.
If it's not under warranty, take it to a local electronics repair store that deals with TVs. Get a quote from them on the amount to repair it.
If it exceeds a third the amount you paid for the TV in the first place (ie if the TV cost you $1,200 and the bill exceeds $400) you're better off to get a new TV.
Posted on Apr 19, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: Clicking sound!
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 15, 2009
I have a 52" RCA
The deflection board needs replacement. You need the PSB260 deflection board available from www.tvrepairworld.com
May 17, 2011 | RCA R52WM24 52" HDTV Projection Television
My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Mar 13, 2009 | RCA R52WM24 52" HDTV Projection Television
My 60 inch rca rear projection tv will not come on hit the power button you hear clicking and the green on light blinks on and off three times
i have had same problem repairman states splitter is bad has an upgrade for $350.00 the next time repaior man could not find part,,advised he would have to replace entire box this cost $275.00 and also states thiis would be a later model than my original box,the picture is great never been this good.note when i say box i ment the box inside tv with all the electronice and projector
Feb 21, 2009 | RCA D52W19 52" Rear Projection Television
Tv light turns on and off ,TV never actually comes on.
CK capacitor cp114,120,150 if ant of these caps are puffed up on top it is bad so replace all 3 capacitors cp 150 is 2200uf 16v other two are 220uf 35v
Feb 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Oct 29, 2008 | RCA D52W19 52" Rear Projection Television
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
[email protected]
Jul 18, 2008 | RCA HD52W58 52" TV
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
