Life fitness crosstrainer 9500 HR has not resistence and just shut down few second after start
SOURCE: hi i have life fitness 9100 hr. it is not
Could be a number of reasons - first to check would be the small micro switch behind the red "stop" button. these sometimes go faulty and will reset the machine at data entry
SOURCE: I was cleaning life fitness 9500 hr with an acid
I'm sorry to say that using the acid base solution destroyed your function pad and will need to replace. Any clean must be done with simple green or warm gentle soapy water. Contact Life Fitness1-800-351-3737 or Nation Gym Supply 1-800-496-7278 give Model and Serial Numbers. Either company will help you.
SOURCE: replacement console
Unplug unit then remove the upper console, their are 4 allen bolts holding it udder the console their is a panel held by 4 phillips head screws also remove them . Look inside the compartment and their should be two connections, disconnect them. Now pull console off its tower. Lay it upside down on a thick towel remove all phillip head screws you'll notice where the emergency stop button is connected. I have found that this connection 7 out of 10 times is causing the problem. Buy cutting the lead connector stripping the wires and soldering back on the male connection will resolve the problem. If not their is a emergency stop kit may be purchased and replace. The only other thing that may cause the problem is the function key pad itself. Try the first solution if your not good in soldiering go to a computer shop , t v shop they should be able to do this very quickly for while your at let the check the switch itself.
Testimonial: "This guy really does know his stuff. I am very pleased I was able to fix the treadmill with absolutely no expense. I simply followed the clear instructions and the machine was up and running in an hour. I would rate this expert 10/10 but actually he warrants 11! maxtreadmill yo da man !"
SOURCE: life fitness 9500 is shocking users? help?
Hi, there is a service bulletin for this problem.
1) perform a continuity test on the power cord between the earth pin at the plug and any exposed metalwork of the treadmill (say an exposed bolt). If you get a reading of less than 1ω - that is good. If higher than this, try another part of the treadmill or trace the cause.
2) Ensure the Power outlet has a good ground - Your electrician could verify this for you.
The most common problems are static buildup on the Striding belt caused by users wearing polyester and scuffing their feet as they are running. This causes static buildup which gets discharged through the user when they come into contact with the treadmill frame.
Happy hunting
SOURCE: How to adjust the tracking
Please read the link below.
http://www.ehow.com/how_5148912_adjust-belt-treadmill.html
