Question about Xact Communication XTR1 SIRIUS Radio Receiver
Xtr7ck satellite radio receiver wont turn on - Xact Communication XTR1 SIRIUS Radio Receiver
My skyfi3 wont turn off. currently frozen on clasic vinyl with no sound
Try unplugging the power cable to force it to turn off. Wait for a minute or so, and then plug it back up. Try powering it back on- that should do it.
Feb 10, 2010 | Delphi SKYFi3 XM Radio Receiver
My radio wont turn on what wires do i need to check
most aftermarket radios red wire has 12 volts when the ignition switch is on and yellow (memory) has 12 volts all of the time
Nov 12, 2009 | JVC KDG320 In-Dash Satellite Radio CD...
Cant receive my channels i have had xm resend the activation signal 7 times and still wont work
First, turn the radio on and off using the POWER button on the radio - do not just turn off the car or unplug it. Next, make sure your 'sleep timer' isn't set. Next, check your antenna signal level and make sure you're in a location that has at least 2 bars - move until you do.
Now, make sure that you leave the radio ON Channel 1 for at least a half an hour. You should then have your channels back - when you do get all your channels back, turn the radio on and off with the POWER switch, not by unplugging the unit, or pulling it out of the dock or turning off the car. Okay?
Oct 27, 2009 | Delphi XpressRC XM Satellite Radio...
Satellite receiver not responding
reset the receiver again and try if its responding again
Feb 06, 2009 | JVC SIRIUS Satellite Radio Interface for...
Can I use a stiletto 2 home kit for my Stiletto 1 receiver?
no sorry it wont the stiletto 1 it deeper than the stiletto 2.
Dec 04, 2008 | Sirius Home Kit for SIRIUS Stiletto 2...
Stuck on 255??WTF
you need to call sirius and activate the new unit the id number is on the bottom sir-alp1 unit or the box it came in
Jan 28, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Satellite radio
Do you Have the right adapter Plugged in??
Jun 22, 2007 | Sirius Satellite Radio Sirius Starmate ST1...
Dropped the unit, doesn't fully power on now
You would first have to open up the unit and look carefully and see what is maybe broken or out of place. Look for loose connections. Check damaged parts.
Aug 15, 2006 | Xact Communication XTR7CK SIRIUS Radio...
Xact Communication XTR1 SIRIUS Radio Receiver Logo
Top Xact Communication Audio Players & Recorders Experts
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
