Televison & Video Logo
emmanuel parcon Posted on Apr 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JVC flatscreen tv model Number AV-21mt35 with vertical interference? how to solve this problem?
Dati pumuputok dahil nakadikit ang high tension wire sa tube.. pinutol ko at dinugtungan at binalot ng insulator, gumana naman subalit meron putol putol na vertical lines na parang interference. paki help naman po sa mga mababait nating kakosa jan
Level 3:
Top Expert:
  • JVC Master 76,851 Answers
  • Posted on Apr 04, 2013
JVC Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007783
Points
237762
It will be best to replace its Line Output Transformer [LOT]. It is not good to join the broken EHT wire. EHT arcing cannot be stopped by using glue.
3 Related Answers
Anonymous
  • 1284 Answers
  • Posted on Feb 15, 2007
SOURCE: JVC AV-20F476
Intermittant issues are always the hardest to troubleshoot. It could be a loose connection or a component that breaks down under load or thermally.
Anonymous
  • 934 Answers
  • Posted on Nov 13, 2007
SOURCE: JVC AV 35750 single horizontal line
Jeremey,
It's ring cracks on the solder joints of the vertical IC... IC421 i mounted to a small heat sink on the board. With the unit off and unplugged remove the board and locate IC421 (LA7832) and closely examine the pins connecting this component to the foil side of the board. You'll notice small rings around the footings that are actually open cracks in the solder, caused by heating and cooling over a period of years. Simply and carefully reflow some solder over these cracked joints, careful not to get the ic too hot in the process, and put it back together.. That should sole the problem...
Another problem we encounter a lot in the vertical deflection circuit of this unit are the two feeder caps C424 (100UF/35V) and C425 (470uf/35v).. If you're already there you might want to go ahead and replace these as well - save taking the back off again if they go bad..
Bill
Anonymous
  • 57 Answers
  • Posted on Feb 28, 2009
SOURCE: RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Can I have a diagram for TV JVC Model AV-21MT35? Anybody can help, thanks in advance.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of many popular brand TVs are given.
Anu po pwd na ikabit na i.c no. sa jvc model av-21mt35
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
1helpful
2answers
My tv is JVC model # is AV-21MT35 the new technician needs the schematic diagram. my old technician lost the parts to be replaced one is for the horizontal out and the other one regulator...
You can use [BU508AF or C3886A OR D5702] as horizontal output. All of these transistors are equivalent to each other, and is commonly used with RCA TVs. But, if there is a fault with its Horizontal output Transformer, {LOT}, none of these transistors won't last long. They will heat up excessively, and will get shorted. Therefore, check whether the LOT has any trouble. Ask your technician. He will be sound enough how to check it. Mo multimeter check is possible with this component. His experience in service work will help him to troubleshoot this problem.
1helpful
I have a 1 yr old samsung flat tv that has a sound but no picture..how can i fix it. i am in an isolated island here in basco, batanes philippines with no experts in repairing flat tv.pls advice. tnx
Kung LCD TV ang unit mo, 3 ang dahilan kung kaya la kang picture.
1. Me pundido kang backlight - kapag me pundido kang backlight kusang pinapatay ng power supply ang inverter board para hindi ma-overload kaya la kang picture. Maaring mong i-check ang backlight, ang palatandaan na ito ay pundido ay kapag me itim sa magkabilang dulo.
2. Sira ang inverter board - ang inverter board ang nagbibigay ng high voltage sa backlight. Kapag sira ito, natural d gagana ang backlight. karamihang sira ng backlight ay ang high voltage transformer, driver transistor o kaya me open na fuse/fusible resistor.
3. Power supply- kapag la supply voltage sa inverter board, la ka rin picture. Mas maganda kung ito ang sira dahil mas madali makhanap ng pyesa dyan sa lugar mo di katulad ng 2 nauna.
Kung me kakilala kang technician dyan malapit sa lugar nyo, patingnan mo yong mga sinabi ko. Maari ring dahil sa loose connection kaya la ka picture o kaya bad solder joints.
Salamat kapatid sa pagboto 4 na hinlalaki.
Jdvillanueva
Las Pinas NCR.
AV-20920 thin horizontal line
hi, usually the cause in jvc tv is, a bad contacts on the vertical chip leges. you should solder those contacts. another option is to change the vertical chip . more rare is a missing of the 27v voltage that goes to the chip. in that case you should check the port of the high voltage transformer.
good luck!
Nagpapatay patay ang fone ko hndi ko alam kong ano ang sira
Hi Ruby kadalasan maengkwentro ko pag patay-patay yong celphone baterya ay sira na,kung sakali bago ang baterya at segurado ka kung hindi ka segurado palitan muna ng bago.Minsan kasi bago mong bili sira pala factory defect ba kailangan original ang bilhin mo or branded ba.Bago na ang baterya ganon parin pa patay-patay parin ,kailangan munang e reset ang setting para babalik sa dati, gawin mo to GO TO> MENU> DEFAULT FACTORY SETTING.Kapangitan lang dito mabubura yong mga save file messages mo kailangan ilipat mo .If hindi mo to magawa dahil patay-patay hindi makaperform ang celpon mo.Kailangan munang pupunta ng cellshop para e flash ang software ng phone mo yan ang nalang option dahil kompleto sila sa gamit mga kable gagamitin pag flash.Meron kung alam saan magdownload ng software para flashing ,kailangan munang kable para makonek sa celpon mo ang data.Just click this site; http://monk3ybidzness.blogspot.com/2009/01/unlock-your-nokia-mobile-phone-with.html
Ibang patungkol celpon problem;
http://www.askstudent.com/hacking/how-to-unlock-any-nokia-based-cell-phone-and-get-its-unlock-codes-absolutely-free/
Feel free to ask whatever the result.
Hope it may help you;
Regards:
VOTIT
taga saan ka ruby?
Jan 28, 2009 • Nokia 3650
A premium problem
Beni maraming salamat saiyo,sa binibigay mo na link medyo,nahuhuli naako meron nang nakakuha ng Best solution.Magtatagalog nalang ako saiyo Ben,nakakahiya saiyo.Hindi kuna aaksayahin itong pagkakataon nato na hihingi ako ng tawad saiyo, "sorry talaga" tungkol doon sa pagkopya ng solution mo,"Cold solder"akala ko noon ok lang,dahil nakita ko sa iba na komopya din,sa solution ko .Dati noong una kung mga solution talagang tinatyp ko mabagal akong magtayp dahil hindi ako sanay sa pagtatatyp at saka sa computer .Kaya lagi akong nahuhuli,hindi ko rin alam ang pagamit ng mga links .Kaya noong nakita ko ang solution mo,akmang-akma sa problema,kalimitan kasi sa electronics epektibo ang cold solder talaga. Maganda ang pagkasulat mo,kaya kina copy paste ko at lagi kung ginagamit ko sa una sa "free solution", hindi ko ginagamit sa "premium solution",iniwasan ko na magkasabay tayo,kaya lagi ako nakakuha ng FIXYA rating free solution. Sa kalaunan akala ko okey lang ginagamit kuna sa "Premium solution" pati,ang iniwasan kung mangyayari na magkakasabay tayo nangyari talaga. Kaya seguro nagagalit ka sa akin,pinopuna muna ang solution ko sa "Misubishi TV tungkol sa sagot ko na "DM" board ,binulgar mo sa lahat saan ko kinokopya yon at tungkul sa kotse din na ginu-googles ko kinuha ang sagot at totoo yon ang lahat nayan,pagtinatamad ako at nagmamadali ako,baka mahuhuli ang sagot ko.
Ang tingin ko seguro nanyayari ito dahil hindi ako nagrespond saiyo sa 'lounge'. Kaya hindi naako pumapasok sa lounge dahil lagi akong pinupuna nila,noon pa. Nagumpisa ito noong nakakuha ako ng FIXYA sa premium solution sa sagot ko sa kotse,tingnan mo ito dito nag-umpisa ang lahat; http://www.fixya.com/cars/t686411-engine_idle
Unang nagalit at nagkomento si ,robotek,tapos nagpa follow up si ekse,sinundan ni abrsvcs,at ibang pang expert na bilib na bilib kay ekse at robotek.Parang nag feel insecure sila pagnakafixya ka o best solution lang.Nakita muna cguro yon ginawa ni robotek sinulat niya ito http://www.fixya.com/ExpertsLoungeThreadView.aspx?thid=718401
Mula nito hindi naako pumassok sa lounge,nakakainis lang minabuting kunalang na huwag pansinin. Lagi ang komento nag googles copy paste,hindi daw ako technician. Maraming top expert nag googles din,si maiksi ,ginko nakasabay ko to sila,tinago ko lang sa premium.Si maiksi lang parang allergic sa akin.Madalas kaming magkasabay,mahilig siya sa maiksi sagot ,parang one liner lang,kaya insecure siya ,baka malaman na siya mahilig mag "place holder",pagwalang makakasabay,saka banatan niya maraming sagot at ang kustomer hindi nag repost kuha na niya. Lagi siyang sumisigaw ng place holder,totoo pala ang kasabihan "kung sinong nagsisili,siya ang hangan". Seguro kung hindi ako technician hindi ako makapasok dito disgrasya lang, ito ang dahilan ;
http://www.fixya.com/support/t668287-burn_resistor Naghahanap ako ng free download schematic diagram.Nagkataon iyon nagpapagaling ako sa operasyon ko sa gall blader.Seaman ako 3RD marine engineer,alam muna pag ang marino nasa lupa ubos talaga lalo na sa kalagayan ko nagkakasakit.May electronics shop ako sa Imus cavite isa at dalawa dito rin sa cebu .Sa pagka ngayon inabalahan ko ay "satellite unlimited" walang load-load,kuha ko diyan sa tondo 5,500 tapos ibinta ko dito sa cebu 25 to 20 thousand,sa bohol ,leyte at saka mindanao.Ang gusto ko sa fixya updated sa repair at makakuha ako ng idea.Sory talaga Ben at saka kay Marked ok lang yong koment mo...
Ikaw Ben tagasaan ka ?Saan ka dati nagtratrabaho..ito number ko 09068050462. Sory pala doon sa lounge bastos kasi yong taong yan si keamo,kabagobago lang niya,kung umasta parang sino.Galit siya sa pinoy tinira din niya si Namizka doon sa car aircon . Hinintay kulang magkamali siya at saka si abrsvs nayan.Etxt muna lang yong number mo...
Oct 01, 2008 • Watches
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
2answers
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
