Question about Ranger Communications RCI-6900F-25 CB Radio
My rci ranger wont transmit but it receives great what is the problem
My ranger rci wont transmit but it will recives great what would be my problem can you tell me thank you.
Posted by kevin mowatt on
dixieoutlaw5
    New Friend:
  • 24 Answers
It could be several things......the rf final,bad mic,cold solder joint on the circuit board just to name a few.my suggestion is to find a good local cb shop,if no local shop find one along the interstate hwy most of the time they are located around or near some of the larger truck stops. tell the tech there what the problem is and go from there. good luck !!
Posted on Apr 06, 2013
2 Related Answers
anymhz
AnyMHz.com
  • 500 Answers
SOURCE: RCI 2970
broken coax inside the radio going to the amp.. is the display ok? sometimes static from storms will knock out the processor and the radios will quit. have to replace the cb shop temple, tx on yahoo search processor board. to restore operation on that problem. is there more info can help us with?
Posted on Dec 08, 2009
Auris
SOURCE: my ranger 2950 wont transmit
my ranger 2950 has no sound some times???
Posted on Nov 19, 2012
Rci 2990
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Apr 19, 2014 | Ranger Radio Communications
Ranger rci 2950 will not transmit
have you tried it on all bands? still won't transmit?take it to a tech so they can fix it properly.
Sep 16, 2012 | Ranger Communications RCI-6900F-25 CB...
I have a RCI 2950 comes on keyed up and stays keyed untill you turn it off. I have replaced the auto amp, all voltage regulators and the black diode with yellow strip below mic plug with no change. I need...
i have the same radio rci 2950. Ive had the same problem with mine,turns out with mine the processor would lock up,turning the radio off & on repeadly would clear the problem and the radio would work fine x-mit & recieve. the solution to fixing the problem is to replace the memory backup battery this battery works similar to a computer motherboard cmos battery when this battery goes dead all sorts of strange things happen to the radio wont transmit wont recieve or like your problem transmits continiously. the problem with replacing this battery is finding out what year & model your ranger 2950 is. the internet says only first generation ranger 2950s use the battery second genration & third generation do not use the battery. but the internet could be wrong. so i suggest getting a hold of (usa ranger.com) & give them a phone call or email and ask them about the year your radio was made. they may even service it for you or if you are electronic savvy you can do it yourself. the battery is located close to the main cpu on the front panel if yours uses a battery.
Sep 07, 2011 | Ranger Communications RCI-6900F-25 CB...
WHEN U KEY UP IT WONT TALK
Do you have receive? If so you might have blew the voice chip. If you don't have receive or transmit you most likely blew those final transistors.
Mar 21, 2011 | Ranger Communications RCI-6900F-25 CB...
My ranger 2950 wont transmit or receive sounds like a relay problem but dont no for shour can you tell me what is wrong with that radio thank you.
could be a number of different problems causing this. I would start with your microphone make sure it is working. it is responsible for transmit & recieve. next check to see if the memory battery is dead this will also cause this problem. next check the regulators in the radio to see if they are supplying voltage.next check voltages in different parts of radio to see if all stages are recieving power follow these steps and something will show up also check your switching diodes to see if they are bad the diodes responsible for x-mit & r-mit of transceiver.
Jan 04, 2011 | Ranger Communications RCI-6900F-25 CB...
I HAVE A SADELTA BASE MIC NEW MODEL ON MY RANGER RCI 2995DX, I HAVE BEEN TOLD THIS MIC COULD DAMAGE THE RADIO,COULD YOU TELL ME IF THIS RIGHT. BACAUSE I AM HAVING GOOD REPORTS WHEN IAM TRANSMITING. THANK...
those mics are supposed to work for most radios ,,,if your getting good audio reports,,i wouldnt worry about it ,,im thinking of getting one for my icom 735 radio,,how much did u pay and where did u get it,,,,if you are worried about damaging your radio,,get a hold of ranger ,,and ask them about the mic
trevor berg
Dec 07, 2010 | Ranger RCI-2995DX Base Scanner
When I transmit on my RCI-995DX people on the other end say that my transmition is scratchy and crackley. I made sure that I as on frequency. Any suggestions? The radio is less than a year old.
Hi, my name is John. Welcome to FixYa. Turn your MICGAIN down a little, or if you have a modulating mic, turn it down. Thanks for choosing FixYa...John
Nov 24, 2010 | Ranger RCI-2995DX Base Scanner
I went to key up my ranger and i could not get it to key up. it had been doing it thing i think it my mic or something
Yes, a faulty mic can cause a radio not to transmit or receive. Try another mic and see if it works then. If it will not key up, it could be the final output transistor.
Does it receive?
Sep 25, 2010 | Ranger RCI-6900F-150 CB Radio
RCI 2970
May 06, 2009 | Ranger RCI-6900F-150 CB Radio
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Ranger Communications RCI-6900F-25 CB Radio Logo
200 people viewed this question
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
