Question about Home
The bras 365+ how come it will not stay flush with the ceiling. Help!!
Posted by slav on
Steve
  • 3,289 Answers
Hi, I'm an electrician and believe I can help you with this problem.
According to the directions I found here, it looks like you are missing the supporting plate with the hook & hole (to pass the cable through) as shown in steps 2, 3 & 4.
You should determine and adjust the length of cable you need to let the lamp hang at the correct height. This length should be between the lamp socket and the hanger. The hanger allows the cable to pass through it and it appears that the cable passes through two openings in the hanger to keep it from slipping through the hanger (and letting the whole assemble fall several inches or more). Then, the cable passes through the hole in the plate into the box in the ceiling for termination of wires.
The cable passing through the two openings in the hanger should provide enough friction to keep the cable from slipping and altering the length of the cable (height above the table / floor / etc) when the hanger is slipped over the hook of the support plate. After you wire nut the connections, secure the support plate with screws to the the ceiling box. Then slip the cone against the ceiling.
If you have the cable routed through the two holes in the hanger, you can either wrap it around the hanger / cord or tie a simple knot in the cable between above either opening in the hanger. This will prevent the slipping of the cable and when the hanger is looped over the hook - the only weight on the cone will be the cone itself. Everything will be supported by the hook on the support plate - which is screwed to the ceiling box.
I hope this helps and good luck!
Posted on Apr 04, 2013
  • 2 more comments
  • Steve Apr 04, 2013
    Either stuff the excess wire in the CEILING box (not the cone) or cut off the excess and discard. The cone is not designed to contain a bunch of excess wire. BTW - the directions supplied are pretty poor.
    It looks like it is designed to carry the excess - but I wouldn't use it to house a bunch of extra cable.
  • slav Apr 04, 2013
    Support plate is already there with the hook. Will try the other steps you mentioned.
    Thanks
  • slav Apr 04, 2013
    Thanks
DGref
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 97 Answers
What I have read is that you must pull the wire through to gather the cone up to be flush with the ceiling.
Seriously I would return it and get another lamp. This does not seem like a good system to me from what I have tried to find out for you.
  • slav Apr 04, 2013
    Thanks was already thinking of that route.
2answers
How much time will it take to learn Microsoft SharePoint and Office 365?
Its depends on the type of skills you want to learn.
1. Superusers: How to use SharePoint upload documents, permissions, create pages with content.
Time: maybe 10 days.
prerequisites: Website content publishing.
2. Developers:
It is technical. It takes a little while to get hands-on experience.
need to learn to programming.
prerequisites: C#, IIS, JavaScript,J Query, Dot net framework,Workflow,database.
Duration: take some time 3-6 months.
3 Admin
It is the configuration of SharePoint on the server and the nature of setting up websites and deployments. Network related, load balancing, Power Shell.
Duration : 3 months.
As for Office 365 it should not take more than 30 days.
Is it okay to wear tight bras?
hi.
Some woman are so used to wearing bras that they even wear one when they sleep! However, a recent study conducted at the Harvard university , has linked wearing tight bras to bre cancer. ... "The main reason why extremely tight bras are bad for bre health is because they restrict the lymph flow in your bre7 Dec 2015
Health impact of wearing a very tight bra - Times of India
timesofindia.indiatimes.com/life-style/health...of-wearing-a...tight-bra/.../6256509.cms
Is it okay to wear tight bras Google Search
What is the plural of armhuman body part in French?
Un bras, des bras
un avant-bras, des avant-bras.
If the singular ends in -s or -x, then the plural ends in -s or -x.
Where is the model number of a flush mount ceiling fan?
Where can I locate the model number of the fan?
There's a gold sticker on top of your fan's motor (the part that faces the ceiling once it is installed). Holding a mirror above the fan motor can help you read the numbers. It may also be found on the parts guide that was packed with your fan or on the box that contained your fan. You're looking for a 5-digit number and it sometimes has a suffix...i.e. 22345A
Where can i find a hanger bracket for Model 42-cl?
Try Switchco at 1-800-365-4548, they have a few styles of hangers. Maybe they can help you. Can't hurt to ask.
How can a flush mount fan be leveled if the ceiling is at an angle?
Flush mount fans are made for Flat ceilings. They are also a waste of money! You won't get any airflow,
My defy daw 365 front loader washing machine won't start. The "end" indicating light stays on and the "door" light does not come on.
hi we just bought a second hand defy front loader washing maching can you please assist us how to use ot its Defy Daw 365 please
1helpful
How does the cover plate attach to the ceiling plate to access the wiring from the ceiling
The trim ring (flush with ceiling) rotates ccw to remove. Than you'll see small screws holding cover in place. Remove, lower cover and wires will be accessible.
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
