American Standard 1748.102 Colony 5.5' x 32" Bath Tub with Integral Apron Logo
Posted on Apr 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I pushed the button down to start the jets and it got stuck all the way down and won't come up
US Parts Center
Level 3:
  • American Sta... Master 719 Answers
  • Posted on Apr 09, 2013
US Parts Center
Level 3:
Answers
719
Questions
0
Helped
284310
Points
1972
When an air button does not come up after being pressed down it is a classic sign that the button needs to be changed.This happens when one of a couple things happen:
  1. The bellows in the air button have broken and therefor cannot push the button back up.
  2. There is calcium built up on the inside of the button
  3. You can clean up the calcium deposits with emery cloth
Rod
US Parts Center
Rgx4634kq2
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 • Dryers
Buttons won't work on my baby lock
Is there one stuck button? Get it loose so the others can be pushed
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 • Dryers
Thrustmaster 458 italia racing wheel won't downshift
lay wheel on sit - look in front of paddle in slot- tiny push button switch sounds like its stuck- qtip and rubbing alcohol lightly
Dryer won't start
the timer could have went out or maybe the door switch is stuck open
Jan 08, 2013 • Dryers
1helpful
Igniter won't start grill
could be a disconnected wire from the igniter. could be a bad ground. could be corroded. Is there a spark going across one of the jets? may need to resort to a butane grill lighter (cheaper than digging around and replacing parts.)
The printer will not start when you push the start button. It is a new printer
Most likely, this issue might be caused by Start button being stuck. If you can't turn the product ON by pushing the Start button, double check if the Start button is somehow stuck, and also make sure that the unit is firmly plugged in to the wall outlet. If that doesn't resolve the issue, try a different outlet because you might be experiencing power outage on the outlet where it's plugged in. If that won't resolve it, I'm afraid the unit has to be serviced.
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
