Question about Jura Capresso Impressa E75 Espresso & Coffee Maker
Jura Impreza F50 Open Tap Problem - Jura Capresso Impressa E75 Espresso & Coffee Maker
4 Related Answers
atgep
Tom Gep
SOURCE: jura capresso
If you gind too fine, it will overload the pump and result in the "open tap" a few seconds into brew. Rinse and gind coarser to clear out malfunction.
Posted on Jan 20, 2008
Anonymous
SOURCE: Jura Impressa E fails to dispense, then gives "open tap" message
I had the same problem, when I called their very helpful customer service, I was given these directions.
Take out the tray.
Inside the machine you can now see a flap hanging from the top.
Reach behind the flap, and you should feel a round object/filter. It has a little dimple sticking out in the middle.
Wipe the filter with a paper towel.
Put the machine back together, and voila you got your coffee brewing again.
Posted on Jul 07, 2009
Morten Bergendahl
  • 60 Answers
SOURCE: open tap - filling system - close tap
Try using warm water in the watertank, important that the water is not too hot, it can cause leakage in the o-rings in the fluidsytem.
Repeat the procedure a few times, if nothing helps, turn off the machine and wait 1 hour and try again.
If you can`t get around this message, then the flowmeter needs to be changed.
Posted on Jul 12, 2009
Anonymous
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
Jura f50 repairing
Probably just needs to be cleaned inside.
This is good video for most models. Parts Guru can do it for you if you don't think you're up to it. Or rebuild the brew group for you.
https://www.youtube.com/watch?v=mZwkqPeZ0QY
Jul 29, 2014 | Jura Impressa F50 Classic Automatic Coffee...
I have the Jura Impressa F50, the machine will no longer function when the coffee grounds conatiner is in place. I have reset the machine several times, have put the container inr\ different positions and...
on the tip of the tray there are metal contacts that tell the machine that the tray is installed. try cleaning these contacts with steel wool and on the inside of the tray with soapy water and a brush. remove excess water from tray and try
Apr 14, 2014 | Jura Impressa F50 Classic Automatic Coffee...
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
When turned on it will prompt "Open Tap" "Close Tab"
There are two possible causes. One is easy the other is hard. So try the easy one first. Remove the grinds tray completely, and place you hand in the cavity that it normally takes up. moving you hand slowly in, feel towards the top. you will find a little flap, past that flap there is the tamper and coffee filter at a slight angle. This may be blocked, so clean with a cloth.
If that does not solve the problem (and 90% of the time it does) then you may have a small spec of dust that is stuck in the water system, this needs to be flushed and cleaned. The best place to do that is with a Jura approved center. Unless you are technically minded. Your local Jura chaps sound like they need a k!$k up their behind
Sep 10, 2009 | Jura Capresso Impressa F7 Espresso Machine
Jura capresso
Nov 17, 2007 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
1,132 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
