SOURCE: HP DV1000 Series (DV1619EA) no sound and modem in WinXP Pro
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
>13
SOURCE: hp 510 notebook -graphics - low resolution
I suggest uninstalling SP3... do you have System Restore turned on? Google how to check...
If you do, try rolling back that way. Start>Run>restore <enter> and the restore window will appear. Choose the restore to an earlier time option, and hopefully a choice for 'SP3 installation' will be there. Choose that to roll back... good luck!
SOURCE: hp 510 laptop drivers
If you follow this link, you can choose your specific laptop from the list. Once chosen, you will be directed to a screen where you may choose your OS. From there, you should find all the drivers and technical information you need to finish your pc.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=510&submit.x=6&submit.y=6
good luck
tony
SOURCE: I have a new HP
This is not related to any Registry keys or .ini file. Actually it's not a problem with your laptop or there's nothing wrong that have been done, but the Fn key is enabled, means the function key is enabled. If you don't want it to be operational, then you have to disable it. But since your keyboard doesn't have a numlock button, you have to do it from the Bios. There an option in the Bios called "Action Keys mode" under "System Configuration" Menu. I would direct you a link instead of giving you the instructions here since you'll need to refer the pictures. Click here and follow the instructions. You have to disable the "Action Keys mode" so that only F1 to F12 will work without Fn key.
If you wish to try another faster trick, give this a try.. Press and hold down both Fn+Alt and hit 0 1 6 2 (zero - one - six - two in sequence) on the keyboard.
Let me know if you need further help.
Good luck.
Thanks for using FixYa.
