Question about Watches
Accutime batman watch time setting
Bought the batman watch for my son however it has no directions to set the time. How do I set it?
  • 1 more comment
  • M Anderson
    M Anderson Mar 09, 2014
    I initially hated this watch. I was up really late the night before his birthday combing the internet trying to figure out how to set the time and date. Here's the secret: There is a big button on the side of the watch. Below it, there is a pin hole size button. Take a paperclip and insert into the pin hole and hold it until the numbers start to flash. Then you use the big button to progress through each number, When you want to move to the next number to set press the pin hole again. I really hope I don't have some of the same band and other malfunctions that I read about as I was searching for an answer to how to set the watch. In the meantime, my son LOVES it and for the price, I will just buy him a new one if it breaks. Good luck!
  • Beauty queen !!
    Beauty queen !! Feb 20, 2018
    Thank you
  • Char Padworny
    Char Padworny Apr 01, 2018
    Thank you!
Joel Waitt
    New Friend:
If it is the Batman watch that has a secret screen that lights up when you pushed the bottom middle of the watch face this is what worked for me.I call that secret middle button the mode button.
push and hold that secret button on the watch face until the hour side of the time starts to blink. let go when you see the hour blink and then you can keep pressing to change the hour. to change the minute I let it go back into sleep mode then press and hold the secret button on the watch face and when it starts to blink let go for half a second and then press down and hold that button again and a minute numbers should start blinking. when they start blinking let go and then push once for each minute. it seems once you start one of these cycles letting go for half a second and then pressing and holding the mode button works. you'll have to experiment with how long to let go and then push.
Posted on Jun 06, 2014
Michael Quigley
Here's the deal with that "mode" button. There are two button pushes you need to use on the mode button in order to set this watch. There is the "single" push which will advance the hour/minute/month/day. And there is the "long" push with advances the mode (from hours to minutes, then to month, then to day, etc.).
Here's the process: single push to wake up the watch, then while the time is showing do a long push to get into "set" mode. The hours will be flashing - use single pushes to advance the hours. Once you're at the correct hour then to a long push until you see the minutes flash. Then do single pushes to advance the minutes to the correct time. Then a long push to advance the mode to the next setting (I have no idea what this next setting is BTW. It looks like it might be an alarm but there's no way to set the hours, so no clue on this). Long push again to get the month, set the month. Long push again to get to the day, set the day. You can long push again to exit the "set" mode or just do nothing, the watch will exit the set mode by itself.
Posted on Nov 07, 2020
Jess Kirkwood
God bless you for these instructions ??
Posted on Jul 02, 2019
Ashley Chenoweth
    New Friend:
Thank you M Anderson for this! Just successfully changed my sons watch for daylight savings time ??
Posted on Mar 11, 2018
1 Related Answer
SOURCE: no watch setting directions
Some of the inexpensive watches like to mimic the expensive watches and put fake dials on the face of the watch. That way you get a Breitling look alike at the price of a Timex. If there don't appear to be controls for the dials, chances are that they aren't real dials, Look closely.
Posted on Jun 15, 2009
How to set time and date on a batman kid digital watch
Is it a BAT 4045? It appears this is a watch with poor or no instructions and ineffective time/date settings, which might be your situation. I found this review on Amazon which might help you.
Solid w/ a configuration issue
Byartayd2on 8 July 2013 - Published on Amazon.com
Verified Purchase
I've seen a few reviews indicating that they could not set the clock or the instructions were not included. While I did get correct instructions, they were not written well and seemed to be the end result of someone translating into English.
I had issues setting the time/date w/ the S2 button initially because of the specific location where you are required to press. It is not sufficient to push the S2 button to begin setting the clock, you really need a pen tip to press it squarely or you will continue to press the button and no time setting options will appear. I originally tried to set the clock by pushing the S2 button with a small thin pair of scissors that were handy but it did nothing even though I was clearly pushing the button into the watch face. After changing to a pen tip it worked right away.
With the exception of the initial time setting frustrations the watch works well and the strap feels strong enough for regular use for my three year old son, and it is pretty cheap!
Nov 26, 2017 | Watches
My son has a Calypso watch model no. k55506/2 We have a problem to set the time. I search for Calypso and keep getting directed to Casio. Is a Calypso watch a Casio model? That's no problem. The...
This also drove me crazy. But I figured it out:
1. Hold the top left button down until "LIGHT" appears at the top; now you are in the setting more. you can turn the light function on or off by pressing either of the right hand buttons.
2. Then, just keep pressing the bottom left button to toggle through each of the settings (date, hour, minutes, etc.); and use the same right hand buttons to set them as needed.
3. When you're done, press the top left button again to complete your settings.
Mar 16, 2011 | Casio Baby-G BG370S-4V Wrist Watch
Lost the manual. Son reset watch. I've reset the
go to www.casio.co.uk go to support(methinks??) click on watches and put in the model number (the one you posted) and download the PDF manual relating to your watch (you will need adobe reader free download to read PDFs), this will be the full manual, once you figure it out DST will have to be on, as its summertime of course. ( i bought a wave ceptor for a fiver because the guy who had it didnt know how to recalibrate it after a battery change), a quick gander at the online manual put it right, there shouldnt be a problem setting it up again, good luck
Aug 05, 2009 | Casio Wave Ceptor Watch WVA510A
Change the day of the week
Most watches have a stem that you pull out to set the time. The little knob on the end of the stem is called a crown. For a day/date watch, there are two clicks. The first click when you pull out the stem is the day / date setting, the second click sets the time.
When you are on the first click, twisting the crown one direction changes the day of the week; twisting the other direction changes the date. If yours has only the date, it could be either direction depending on the manufacturer.
Jun 15, 2009 | Guess Collection Textured Dial Watch
Can't set the time!!!!
the instruction aren't much help either. this was a watch they discontinued pretty shortly after they released it. poor instructions and poor usability. great watch company though. this one was just a dog.
this was taken from a page off amazon: "Try to use the following for setting.
Press/hold with the upper left button until LIGHT OFF on the display.
Use lower left to select hour, min, date........
Use upper/lower buttons for adjust hour, min, date......
Press upper left to exit setting."
it worked for me. i have several of their watches, but like i said, this one was one of their "dogs"
Feb 14, 2009 | Freestyle Cortez Mid Watch
DZ7081 Diesel Digital Watch
Diesel Time Frames Customer Service
2280 N. Greenville Ave.
Richardson, TX 75082
TEL: 800-699-2556
[email protected]
Sep 30, 2008 | Diesel Audio Diesel Watch
No instructions
I just bought the same watch for my son, and it also came with no instructions. I can't figure out how to set the time.
Dec 12, 2007 | Watches
Timex Expedition watch
I bought this for my son and he has been living with it for 4 months, and hour and ten min. off !  I just want to set the time, and I'm at the top of the world, no radio shack down the road.  Turn right at the polar bear.
Oct 12, 2007 | Timex Expedition47761 Wristwatch
User manual for Diesel watch
I was given two different Diesel instruction books with my dz-7069 and neither covers the watch in question. If anyone can tell me how to set the time on it I'd be most grateful.
Aug 15, 2007 | Diesel Audio Diesel Watch
Watches Logo
15,925 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
