Question about Polaroid Televison & Video
Can't play avi videos usb
Polaroid tv P32LED12 Put films on a usb stick and tried to play but NOTHING works! all say 'unsupported or invalid file' (or something similar). Not had this problem on any other tv i've tried (and i've tested it on 6 others!) Help!
Posted by Lucy Daniels on
  • Robert Stenhouse- Don
    Robert Stenhouse- Don Apr 17, 2015
    further answer given on 2 tips published
Nanny
    Genius:
  • Polaroid Master
  • 2,351 Answers
You can try to download an AVI player program and you will be able to play AVI file on computer.
Leawo Free Blu-ray Player has the ability to perform as a multi-functioning AVI video player to play AVI files on Windows and Mac easily. It is capable of recognizing videos and audios in 180+ formats. Featuring 4K resolution video playback, this free AVI player program has all the solutions for Blu-ray discs, DVD, and 4K Blu-ray. During AVI playback, users will get the 100% original video and audio quality.
Posted on Apr 22, 2020
    New Friend:
  • 3 Answers
Hello to all. Have twin boys staying over the holidays and they wished to view movies when they went to bed. have Polaroid 32" P32LED12 fitted to their bedroom. The tv is ok for playing dvd through it but when on using the usb drive with movies on it, it came up Invalid or Unsupported file. Have tried different movies with different formats and came up with nothing to play. So got myseld a video converter program: Wondershare video converter ultimate. On looking at the booklet from Polaroid, it says MPEG1.2, but although on converting the film to this format, the film broke up. So I took an AVI trailer and converted the trailer to all the formats on the converter and stuck this on the USB and stuck it into the tv. Out of all of them, i found that the converter format was VOB DVD FORMAT in this coverter. The film did not break up and the sound great. The film sizie was a bit smaller in frame size but this can be increased. What the converter showed after the conversion was: DVD-Video/ Format: VOB. Video Codec: MPEG-2/ Audio Codec: MPEG-2 audio. There is a settings on this converter at the lower right corner, but you can fiddle with this yourself. But to finish with, I have tried most of the films with different formats and could not get them to work on this tv, so get yourself a video program converter, put in laptop or pc and convert film to VOB. Hope this helps as there is nothing in any help on google for this tv.
Posted on Apr 13, 2015
2 Related Answers
Azrael SRL
  • 11800 Answers
SOURCE: ive formatted my 8gb flashdrive
AVI is just a format - the video inside it can be coded using just about every codec. That sharp supports files that are coded using DIVX 4 to 6 and XVID 0.8 to 1.3. You must make sure that the avi files were coded correctly. For that install this program and use it to check the files
http://mediainfo.sourceforge.net/en
Posted on Jul 19, 2011
vinceisaac
francoise cleofas
  • 2432 Answers
SOURCE: WHAT VIDEO FILE PLAY'S VIA THE USB
tried with other files doesn't work like mpeg4, divx and jpeg?
Posted on Oct 28, 2012
Can I watch a film on a USB stick from the service USB port?
Yes, if your tv has the appropriate software built in to play the video files on your stick. It has been my experience that many tv's lack the proper codecs for playing some files. Your blue ray dvd's with the usb input usually play lots more of the files.
tip
How to view videos on your usb in the Polaroid P32led 12 Television.
I related my earlier finding on how to put a film onto your usb to work in the Polaroid P32led 12 Television. I found that it was a VOB file?  I have now again fiddled about and found that if you install this program into your Pc:- BIGASOFT MP4 CONVERTER V.3.6.10.4437 or newer version, then setting the output format to:- VCD VIDEO (*.mpg)____Video Size:- 352 * 288cif____Video Quality:- Higher___Audio Quality:-Higher.     You then find the film for converting and copy/insert into program, then convert to desktop or folder you have made on the desktop.    This is very quick with this program. When finish and on desktop, put your usb into the computer then bring up the usb folder.   You then copy his film by left click on the film/desktop then right click with mouse then copy then take pointer over to usb folder, left click then right click in usb folder, then paste the film into it. when copied, take out usb and try in tv, should have video and sound.  just do the same again for any other films.
2answers
Hannspree hsg1075 says it plays video from USB but has no video in input menu.
Notes:
• It does not support "NTFS" and the maximum file size of a single file is 4GB.
• Progressive format jpeg files are not supported.
• Due to the compatibility limitation, not all of USB devices are able to be
displayed properly.
• Operation using USB hubs is not guaranteed.
• Due to the compatibility limitation, not all of external hard disks are able to be
detected correctly.
• Cables used to prolong the USB device must be certified as USB 2.0.
• In USB devices, video files may not be played properly if speed is not enough.
2answers
Invalid or unsupported file
Check the TV manual for which movie file format will run from the USB port on the TV.
You may need to convert your movies to a file format the TV uses.
Check out this WEB site for video file conversions.
http://www.fixya.com/support/r5874192-play_videos_mp3_player
Eh5000 wont play movies on usb stick
The TV can only play a specific format of video. You may be using MP4 files while the TV can only view 3GP or FLV formats; just try downloading a converter (I've used FLV Converter on Windows XP for years, works fine and very simple) and changing the file format.
1helpful
Useing external hard drive to record films to play back through tv connect to usb and it showes unsupported devise what is the solution
check what type of file extensions your tv plays and only load those kind of movies onto your hard drive.
1helpful
2answers
Canot play media on television from Hitachi 500GB Touro Mobile USB 20
Check the supported movie files that can be played on that tv then look at the file and see what type of file it is. I recommend using MP4, WMA or AVI files
Hi -- i have a problem? regarding my sanyo CE26LD47-B television the tv itself is ok!,--channels etc., but it has a "usb"connnection, and i want to play my external hardrive through the...
If you were to find a film that works then look at the format of it on your PC. Converting the films that don't work to the same format should do it.
Televison & Video Logo
Top Polaroid Televison & Video Experts
Paul Bade
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
