Question about Mitsubishi MSH09TW Air Conditioner
Just so you know, you can use just about any condenser coil as long as it uses the same refrigerant as your original system does and if it will physically fit and has the capacity of the old one. However before you go out and buy something have you tried fixing the leak in your condenser coil? If it is made of copper then it is easy to solder with silver phosphorous and using a presto-lite torch. If you don't have one then you might try using map gas. As long as you can get 1,000 degrees or more it should work.
Good luck
Marty
Posted on Mar 01, 2014
Apr 17, 2014 | Mitsubishi MSH09TW Air Conditioner
Aug 27, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Jan 11, 2010 | Fujitsu Electronics - Others
Dec 30, 2009 | Asko T780 Dryer
Nov 01, 2009 | Heating & Cooling
Sep 01, 2009 | Goldstar M5200R Air Conditioner
Jul 31, 2009 | Mitsubishi MS24WN Air Conditioner
Jun 27, 2009 | Heating & Cooling
Jun 03, 2009 | Weather King 10AJA6001AH Air Conditioner
Feb 05, 2009 | Mitsubishi MSH09TW Air Conditioner
75 people viewed this question
