I have a acer tablet 500 and it is stuck on the home screen of acer it originally showed acer screen android screen loads a bit then to my home screen where apps wallpaper etc. is at so if u have a solution please help me out
SOURCE: i dropped my android tablet
You can get the part at android Repair and there is a guide that shows you how to put in the part at tablet Repair Guide.
SOURCE: my binatone homesurf tablet is stuck on the home screen and wont do anything can you reset it
Sounds like it needs a reset.
The Binatone Helpline is available from 9.00 am to 5.00 pm, Mondays to Fridays, please call0845 345 9677 for UK+491805938802 for EuropeAustralia customer service number 1300 768 112 or email to [email protected] India customer service number +91 7503011385 or email to [email protected]
http://www.binatonetelecom.com/binaries/content/assets/binatone/products/android-products/homesurf-7/pdf/homesurf_7user_guide.pdf
The manual has very limited troubleshooting, so it looks like you'll need to call them.
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
SOURCE: every time I open my galaxy tab. I can not access
touch and hold on pressing the home key until a task manager note will pop out end the recent tasks or uninstall the programs that u suspect making problems. my galaxy was having problems with viber and what's up communication apps i uninstalled them and the problem was solved automatically
