Question about ZEEPAD VIA8650 Android 2.3 Tablet
My zeepad 7.0 battery is dead - ZEEPAD VIA8650 Android 2.3 Tablet
Posted by Donna Masters on
Norm Pope
    New Friend:
    Problem Solver:
  • 4 Answers
Check to see if charger is working either a voltmeter or touch to your tonugne , actually less of a tinge than a nine volt batery.Make sure charger plugged in to wall( my charger was DOA from the ware house but I used the plug from the new charger with one of my old wall charger units ( 5 v or maybe 6 volts in a pinch only) and after a 4 hour charge she was ready. Hope this works for you also
Posted on Jan 02, 2015
pmcastillo79
    New Friend:
  • 7 Answers
Hi, Zeepad battery is PBS01SHz10 is a japanese battery, similar to nokia BL-5k battery.
Open a zeepad is easy, the problem to find these kind of battery. I am thinking in change the internal connector to adapt the nokia n86 battery, is more easy to find almost here in Venezuela.
Posted on Apr 28, 2013
My son's Zeepad 7.0 won't turn on.. tried charging it. Unfortunately, still nothing. He has had it almost a year.
Most probably there's a break in the charging circuit. Is the charger in working order? CHECK THE OUTPUT VOLTAGE OF THE CHARGER. Try booting with the power connected. If it starts, then the battery is dead. If still doesn't work, then need to check internal circuit.
Jan 05, 2015 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
MY ZEE PAD WILL NOT CHARGE
both of my charging ports are bad , thats your problem also, we need to find a supplier for the parts so they can be fixed..
Dec 19, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
How to extend the short battery charge on Zeepad
You can decrease LCD brightness to improve you battery time
Jun 30, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Why wont my zeepad charge all the way?
Battery getting old and need of replacement , is the typical reason for devices to no longer charge correctly.
Jun 03, 2014 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
Why wont my zeepad turn on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
May 10, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Repair for Zeepad Allwiner
Is there a charging indication? if so, keep it off, and leave it plugged in, for a long time. I'd say a few hours to a day. Then try to turn it on.
May 02, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
ZEEPAD VIA8650 Android 2.3 Tablet Logo
158 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Paul G
Paul G
Ngoro
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
