Question about Scubapro Subgear Xp-10 Computer 3 Gauge Console, With Usa Manufacturers Warranty
Computer Malfunction I received an error code "E3" to replace the battery after a dive. After replacing the battery computer was in working order; turned off the computer and one second later the computer turned its self on. The only way to turn it off would be to remove the battery again, which I am reluctant to do. Any help with this problem would be great.
Posted by kovermanryan on
thomas chan
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Scubapro chromis E6, how to unlock the computer.
Posted on Apr 08, 2017
Dan Jacobs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 808 Answers
Call scuba pro they can assist you with problem if they can not fix it over the phone send it to them for repair or replacement.
Posted on May 16, 2014
Battery replace for Citizen Cyber Aqualand NX
My Cyber was working fine and reporting a full charge, but when diving, it would stop working and go into safe mode. I sent it in to Citizen and they replaced the cell, now all is good again.
Mar 06, 2013 | Citizen Promaster Cyber Aqualand Nx Dive...
O/d light blinks when driveing o/d seems to be engaged car has 198000 miles and runs very good also engine light is on
O/D light blinks, but with that the check engine light is ON.--- This will make your troubleshooting easier.When the check engine light comes on, and remains on, this indicates that there is error stored in your cars computer.---- Once the computer is scanned, you will get error codes, as per that error code it will point towards faulty part, which is causing the O/D light to blink.-------- Most probably the O/D light blinks, If a problem exists in No. 1 or No. 2 solenoids or speed sensors .
--------------- For car after 1995 it requires OBD2 tool and for car before 1995 it requires OBD1 tool.------- --------- You car will require OBD1 tool.There are very few auto parts store and repair centers who have OBD1 tool.In your case you required OBD1 tool.------ You can just contact local auto-parts store and they will guide you to the nearest store who has OBD1 tool.There you can get your car scanned.If there is error set in your cars computer, then you will receive the error code.As per error code it will point towards the faulty part causing this problem in your car.------------- -------------- The codes which you get is scanning will be mostly any of this following codes:--- DTC P0500 - Vehicle Speed Sensor Malfunction
. DTC P0750 - Shift Solenoid "A" Malfunction
. DTC P0753 - Shift Solenoid "A" Electrical Malfunction
. DTC P0755 - Shift Solenoid "B" Malfunction
. DTC P0758 - Shift Solenoid "B" Electrical Malfunction
. DTC P0770 - Shift Solenoid "E" (SL) Malfunction
. DTC P0773 - Shift Solenoid "E" (SL) Electrical Malfunction
. DTC P1520 - Stop Light Switch Signal Malfunction
. DTC P1705 - Direct Clutch Speed Sensor Circuit Malfunction
. DTC P1765 - Shift Solenoid Valve SLN Circuit Malfunction
. DTC P1780 - Park/Neutral Position Switch Malfunction
--------------- Now it all depends on what code you get, as per that you can replace the following part.------- This will help.Thanks.Helpmech.
Jul 07, 2011 | 1995 Toyota Camry
I have a Daytek air conditioner and it is giving the following error message E3 What is the problem and how do I fix it thank you
E-3 means indoor motor mechanism locked or no power to motor.Check& rectify motor and PCB.
Jan 11, 2011 | Heating & Cooling
I have an Oceanic Veo 100 Dive computer, and It has been working very good It has never fall down or recieved any damage, but the first time I changed the battery, It show the error BAT, and it does not...
Generally dive computer batteries are NOT a do it yourself job and need an authorised dealer to undertake. It is imperative that the correct battery is used and that the watch is pressure tested for leaks and calibration. I recommend you send your computer to an authorised scuba service centre. Sorry, hope that helps.
Sep 07, 2010 | Oceanic "Veo 100" Dive Computer Triple...
Hello I am getting error code E3 on my Baumatic dishwahser- how may I resolve this? Thank you
its "malfunction of temp sensor or heating element"so it is either the heating element or temp senser.is faulty test and replace the faulty part
Nov 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
ERROR CODE E3 -50 (PANASONIC FP 7742)
E3-50 is the malfunction of the transfer wire cleaner. The transfer wire assembly is under the drum. The transfer wire is on the right. The cleaner moves back and forth. If you feel comfortable taking it out, respond. There are fine metallic wires in each slot, so don't break them
Oct 04, 2009 | Panasonic FP-7735 Black and White Copier
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Scubapro Subgear Xp-10 Computer 3 Gauge Console, With Usa Manufacturers Warranty Logo
2,198 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
