Question about Cameras
The lithium battery won't charge
From new last christmas never charged. It works if switched on wile plugged in for charging but not when unplugging charger from mains. It's as iff the battery does not charge at all.
Posted by oyvind tangen on
Chris Hingee
  • Cameras Master
  • 32,281 Answers
If the lithium battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Apr 03, 2013
5 Related Answers
Anonymous
SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Posted on Jan 16, 2008
Anonymous
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Posted on Sep 26, 2008
Anonymous
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
Anonymous
SOURCE: Sony cybershot f717 battery won't charge
Same for me too... And a bunch of other stuff! I can't choose to have the flash, can't use the veiwfinder...
Posted on Oct 31, 2008
Anonymous
  • 3 Answers
SOURCE: I lost my battery charger and i need to charge my camera battery
you now can buy chargers to replace lost ones, i work in a camera shop and sell a brand called Hanmel. they do a range of the most popular brands of camera chargers, just check the back of the hamnel packaging it to see if it it compatable with your battery
Posted on Apr 13, 2009
Why so long when i'm charging my lenovo a1-07 ideapad
Frequent Charging Shortens Battery Life Frequent charging shortens the life span of a Lithium ion battery. Batteries should be charged only after they expend all their power. b> Switching Batteries Switching batteries helps preserve battery life: If a cell phone or computer user puts in a spare battery while separately charging the primary Lithium ion battery, that helps extend the life of both batteries. b> Removing Batteries Most laptops charge the battery when a user plugs in the AC adapter. Users can adjust this setting by changing the power options. Windows places this option in the Control Panel, while the Gnome Linux desktop places power options under "Administrative Tools". Cell phones incorporate their own power-saving features that the user usually cannot control. b> When to Replace a Lithium Ion Battery If a laptop battery does not hold a charge for more than a few minutes, a user must replace the Lithium ion battery if he wants to use the computer without an AC adapter. Other Ways to Extend Battery Life Storing a battery in a cool, dry environment causes a lithium-ion battery to last a little longer and reduces the frequency of needed battery replacements. Hope this helps.
Dec 29, 2012 | Lenovo IdeaPad A1 Tablet with 16GB Memory...
WORX 24V charger won't charge
I'm having the same problem. Worked great then didn't last as long. Now I'm stuck with this piece of crap useless piece of equipment. I'm back to spending too much time trimming with scissors since I can't afford a new battery non the less a new trimmer. Thanks a lot WORX! It doesn't Work! I'll never buy another of their product!
Aug 26, 2012 | Worx 24-volt Cordless Electric Lithium-ion...
Why Power Tool batteries can't charge to 100%?
Batteries wear down over time. The cells inside them don't work as well at holding a charge compared to when they were brand new. So after using them for a while they begin to last a shorter amount of time.
Lithium Ion batteries last longer and don't wear out as quickly. NiMH batteries are next in reliability. And NiCad have their own issues.
Aug 13, 2012 | Drills
Dewalt lithium battery won't charge
Your problem states you have a Makita tool and your question is about a Dewalt lithium battery. In either case if the battery won't take a charge or if the charger is showing the battery is defective the only fix is to replace the battery. Some causes for defective batteries or batteries that won't take a charge are bad cells in the battery, bad or shorted IC board in hte battery, broken or burnt connections between the many cells or between the cells and IC board or even bad or old cells that will no longer charge up. The time and effort needed to find out what the problem is then finding another battery to scavenge parts from (individual battery parts are not available) is never worth the cost of just buying another battery and going back to work with the tool(s).
Jun 27, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
What causes a lithium battery to only partially charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 25, 2011 | Drills
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Will not charge
batterys dead, these usually last for about 12-18 months.
you can probably buy a replacement, but may have to get the shop to fit.
Due to data loss et,c.
Use it on the computer with a USB lead.
Mike @ Compurepair.
Feb 25, 2008 | JVC XA-F107 MP3 Player
Cameras Logo
345 people viewed this question
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
