Clicking or spray noise on my '03 Audi A4
I'm not sure what is causing the noise, but if the timing belt was broken, your engine would be trashed and would've shut off as you coasted to the side of the road, so I wouldn't sweat that. I'd take it back to the dealer though, and have them test drive the car and check it out - since it seems you just picked it up from them and are now hearing noises you never heard before, it's possible that they didn't set something up right. Try and use every feature our car has - AC, heat, defroster, power steering, you name it - any feature your car has, and see if any of them don't work anymore, as that could help localize the problem.
You said something was "spraying" - I'm assuming not a liquid, but more of a rushing air noise. That would signify a vacuum leak, as if a vacuum line were damaged, pinched, or not reconnected during the servicing of your car. Be sure to bring that to their attention.
If something turns out to be damaged, and they give you a hard time, take your car to an independent Euro mechanic, have them verify the problem, and call the dealer back with the assessment of the independent mechanic, and force them to take care of what they broke. If they refuse, call a lawyer and try again (I'm only mentioning this because a lot of people I know have had trouble getting Audi dealers to rectify problems they create).
