Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
There are two TV's that respond properly to two working dstv pvr remotes. tv1 is supposed to only respond to the remote on a red dial and tv2 to the remote that is on the blue dial. tv1 is connected to the pvr decoder directly and tv2 uses a mouse. tv2 only responds to a remote on the red dial. it won't respond to a remote on the blue dial, like it should. I have restarted the decoder, unplugged and replugged the mouse, but nothing has helped.
Posted by Catherine on
Francois Hugo
    New Friend:
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Posted on Apr 15, 2013
Testimonial: "Hi, yes it seems they both were set to the same channel. I later phoned the DSTV office in my area and ran a test as per instruction by phonecall, but it did not respond as expected in the test and there turned out to be no simple solution, thus we had someone come in and disconnect, reconfigure and reconnect everything. Long process indeed. Their leaving statement was that the the technician who had installed it had missed a minor detail which later lead to such problems. But it has not happened again thankfully. Thanks"
5 Related Answers
kz101
SOURCE: Hi, My DSTV decoder is
press the shift button, its stats flashing than press the info button (tv1) works every time
Posted on Feb 08, 2011
Anonymous
  • 56 Answers
SOURCE: In single mode, my remote for TV1 works, but in
Your shared view is enabled. , press the menu button, then option 6 then option 2, disable shared view then select done. ( this can only be done in single mode) then go back to dual mode.
Posted on Nov 12, 2009
mary jane
SOURCE: my samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Posted on Dec 13, 2011
muntejaya
Muntejaya Ginting
  • 10422 Answers
SOURCE: I have two Samsung HD
Hi, To change one of your TV with another brand is not a wise decision indeed. Well, Your TV has a remote sensor in the front side. Try to places both TV on opposite position. Otherwise use the used batteries on both of your TV remote commander. This will reduce its signal.
Regards
Posted on Jan 17, 2011
CheriT Dish
Cheri Torres
  • 146 Answers
SOURCE: I have 4 TVs using
Hi, Cheri Torres with DISH Network Customer Service here. Icame across your question and wanted to see if I could help. It sounds like youmay need to either readdress your TV4 remote to your 322 DISH receiver or youcould possibly have receivers for TV2 and TV4 mixed up. Since your TV4 has "Pressselect to watch TV" on the screen you can check both of your receivers andwhich ever receiver has the TV2 blue light off is the receiver this TV runs offof. If this is not the case and you are positive that the TV4 does run off the322 you will want to take the remote to the receiver box location in order toreaddress it. I will list here for you the instructions for readdressing theremote to the receiver box. I hope you find all this information useful and ifyou have any other questions or this does not fix the issue you are experiencingfeel free to email me at [email protected] Thanks and have a greatday!
Instructions for readdressing your remote to your DISH receiver
  1. Go to System Info screen. You can do this by pressing the power button once then the channel up button once on the front of the receiver box.
  2. Once you are in the system info screen you will see primary remote address and secondary remote address.
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the little white square for secondary remote address.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 4 will appear in the System Info screen under Remote Address.
Posted on Feb 16, 2011
Testimonial: "Thank you Cheri Torres. I have been working on this since 4:00 yesterday afternoon. It tool less than an hour to get a real answer. Nice site."
Dish remote 2 changes channels on both tvs and dish remote 1 changes channels on both tvs
Is the receiver in dual mode? Go to the receiver, open the door, and hit the mode key. If both TVs are still showing the same thing, then the issue is not the mode.
Go to TV 2 (the one without the receiver) and make sure the TV is tuned to channel 60 or 73. If it is still showing the same thing, go to TV1 (the one with the receiver) and hit Menu, system setup, Installation, modulation (menu 6-1-5). make sure the modulation for tv2 matches which channel you put your tv2 on.
Still showing the same thing? check the back of the receiver, the RCA cables (red/white/yellow) are plugged into the TV1 ports not the TV2 ports.
Showing different things but the remote still changes channels on both tvs? Go to TV1, hit menu twice, near the bottom there are two boxes each with a number. This is the address for each remote (tv1 and tv2). On the TV2 remote hold sat until it stays lit, choose a number different than on the screen, touch pound (#), the sat light blinks three times, hit record, the number on the screen should change to match the one you typed in.
Still being silly? Call a priest, you have a poltergeist!
Oct 24, 2013 | DISH Network IR Remote Control
Tv2 remote not working tv1 must be on
It sounds like the RCA cable is plugged into TV 2 ports on the back of the receiver.
Depending upon your receiver, towards the center on the back of the receiver, you have 3 rows of colored (2 - Red, White, and Yellow; 1 - Green, Blue, Red). The RCA for TV 1 should go in the middle row. Please let me know if you have further problems. Thanks.
Dec 16, 2011 | DISH Network IR Remote Control
How do i tune tv #2 from the reciever or the 1st remote? dish network dual reciever, silver remotes.
I'm not sure I understand your question. If you are trying to use a second TV without a remote or if you are trying to set up TV 2. The two remotes are different so, they will not perform on both Tv's. Please gine me more info on what you are trying to do.
Thanks,
Dave
Aug 08, 2011 | DISH Network DVR-625 DTV Receiver /...
I have a new DVR 622 reciever, the UHF remote(TV2) does not work at all, I have tried to program it, but itdoes not seem to work.(does the TV2 need to be hooked up to the receiver to et the remote to...
Hi Rich, myname is Mike Houston of DISH Network and after going over your post I see theTV2 remote as well as other issues with TV2. There is a easy fix to this so youcan enjoy both TV's, on the receiver you will want to make sure it's in DualMode, you will see a Yellow, Blue and Green lights on the front of thereceiver. I will send a link to help with the steps of setting up the remoteand making sure the TV2 is configured correctly and on the right channel. http://www.dishnetwork.com/SupportSection/troubleshoot
Apr 18, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Cannot get it to work with dish network. It won't accept channel input either!
Hello! If your tv just won't cycle to the correct channel you can change the setting if its tv1 you need a channel scan if it's tv2 try these steps:
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
Dec 31, 2010 | Insignia IS-LCDTV32 32 in. Television
My remote control only works for tv on & off and volume but not to change dish channel
I experienced this problem as well. I have a dual receiver and had issues turning channels on TV2; but counld easily access the volume. After reading the Dish manual, I learned that my TV1 and TV2 remotes connect through different signals (IR = infrared for TV1; and UHF= ultra-high frequency for TV2).
Check your remote to see if there is a UHF logo at the very bottom (under the Dish Network logo). The UHF remote sends ultra-high frequency radio signals to a UHF antenna which is connected to the back panel of the receiver. Make sure that you receiver is properly dusted and then check to make certain that the UHF antenna located on the back of the receiver is positioned straight-up. When the antenna is not correctly positioned it can cause problems with your remote signals.
Oct 06, 2010 | DISH Network IR Remote Control
The receiver is not reading control remote No.2. the control works, but the receiver does not respond to it. Could it be the antena?
It could be the distance the remote is from the antenna. Try going to the receiver and pressing the guide button on said remote. Go back to TV 2 and see if it is up. If not go back to tv 1 and with TV1 ON AND TV1 REMOTE IN HAND press MENU-MENU. You will be able to see the remote addreses for the remotes toward the bottom of the page. With TV2 remote in hand press and hold the SAT button in the upper left of the remote until all buttons across the top illuminate. Now press in a trwo digit number between 2 and 15. Press the pound sign and the SAT button will flash thrice. Now press record a few times until you see the TV2 icon on the screen blink and the address is the same as you keyed. Exit out of the menu with TV1 remote. Go to tv 2 and try. You should be good to go.
Thanks for using Fix Ya.
Dec 14, 2009 | DISH Network DVR-625 DTV Receiver /...
In single mode, my remote for TV1 works, but in dual mode, only my remote for TV2 work. In single mode, both remotes can change channels, record, etc. In dual the Remote for TV2 turns on the blue light and...
Oct 28, 2009 | DISH Network IR Remote Control
Remote Sensor Problem
Given that both remotes work with TV2, more likely the IR sensor on TV1 is defective.
The problem could also be in the microprocessor itself as well.
Feb 17, 2008 | Symphonic WF20D4 TV
Televison & Video Logo
671 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
