SOURCE: I need a power supply for a White 4400 embroidery
Local computer stores carry Universl power adapters. These spec are very common on off the shelf power adapters.
You power supply specs are:
DC 6V power UL Power supply at 800mA
Or you can order from this site:
http://www.whitesewingcenter.com/index.php
http://www.whitesewingcenter.com/orderform.php
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I have a new windows
Unfortunately, it seems that the company that bought the White brand (SVP) has no interest in creating new drivers for the machine. Is your computer running the 32-bit or the 64-bit version of Windows 7? (Start > Control Panel > System and Security > System. If you see x64, you have the 64-bit version.)
If you have the 32-bit version, you can try the compatibility mode. With the White USB drive connected to the computer, right click on the installer instead of normally running the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties.
A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software that came with the sewing machine in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
SOURCE: My top thread does not
Take off your throat plate and make sure that there is not a piece of your needle still in there, brush it out and oil your machine if it needs it. Now rethread.
SOURCE: i need an install code for a white embroidery
Try any one of these code JYAI-HSEJ or VXLR-DMXN.
Hope this helps, thanks!
