Question about Packard Bell Computers & Internet
Why won't my packard bell's cd disc or floppy disc drive won't open
  • 2,878 Answers
CD / DVD and most optical drives - Manual eject by sticking a straightened paperclip in the tiny hole and gently push open.
Posted on Apr 10, 2013
6ya staff
SOURCE:
benwabnick
Ben Wabnick
  • 2404 Answers
SOURCE: acer 4420 laptop.vista windows,d drive
Take a can of air and blow some onto the laser of the drive so that way you know for sure its not dust or dirt on the laser that is causing it not to read.
After you do that if the drive still won't read any discs then you know the drive is bad and it'll have to be replaced.
Posted on May 15, 2011
David Petry
  • 961 Answers
SOURCE: My system just displays Bad
This is Asus's link for your board, you can click on the download tab, scroll down to and select your operating system, then download the latest Bios for your board:
http://www.asus.com/Motherboards/Intel_Socket_775/P5S800VM/#
Posted on Jun 16, 2011
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: Gigabyte GA-7DX+ won't power up. Checked
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge Cmos battery on some motherboards are soldered in
hope this helps you
Posted on Oct 02, 2011
Terry Hair
  • 4134 Answers
SOURCE: can i upgrade my packard bell 5090 motherboard?
No. And old isn't what your PC is......it's ancient. Packard Bell machines from that era were in proprietary cases, making upgrades difficult if not impossible. Additionally, the power supply will probably be underpowered and will may not have the correct power connectors for modern mainboards . It's time to part with the old relic and get a new one.
Posted on Feb 01, 2012
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: trying to rewire a packard bell media5118
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
http://www.innovative-sol.com/drivermax/
free program, paid update available
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Posted on May 16, 2012
Packard Bell Master CD
If I where looking for this, I'd hit up yellowpages.com and look for all computer shops, antique malls, pawnshops and flea markets in the area and start making calls to see if they have antiquated technology laying around.
I, personally, love tinkering around with these old machines. It's been a hobby since they where new! lol And I'm a pawn broker, so I'd be one shop that may have what you need. (I don't, unfortunately, I looked.) And you'd be shocked what all you can find for a quarter at a flea market or an antique mall.
Mar 06, 2014 | Computers & Internet
My packard bell dots won't accept my password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jan 31, 2013 | Packard Bell Bios Chip: Dot S
My Packard bell pc won't turn on an keeps making a
The number and timing of beeps will tell you what's wrong. You'll have to find the motherboard manual to find what the beeps mean though. Would be worth taking the RAM chips out, blowing any dust away and putting them back in.
Apr 20, 2012 | Computers & Internet
PACKARD BELL LJ71 WON'T START UP
can you be more specific as to the actual text? Also you should press F2 or whatever key is your bios hotkey and check your boot order. Make sure that the hard drive is your first boot device. it actually kind of sounds like you have a cd in the drive and it's trying to boot from it. please physically verify that there are no discs in the drive.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Feb 26, 2012 | Packard Bell Computers & Internet
My packard bell won't load windows. When i turn it on the packard bell logo appears and then a black screen with American Megatrends appears with which Function keys to press and at the bottom of the...
try to change your cmos battery,and first boot your hardrive,and set your time and date properly then save your settings take a look if your settings will be save.if yes,that means your cmos battery is the isue.
Sep 14, 2011 | Computers & Internet
I want to reformat PB MS2303
Packard Bell is a computer manufacturer, now owned by Acer. Restoring your computer will erase the hard drive and install a fresh copy of Microsoft Windows. This is beneficial if the Packard Bell is showing its age and running extremely slow or has been hit with an incurable virus infection. Before attempting to restore the system, be sure to back up any data you wish to save.
1.Insert the Windows Setup CD/DVD into the computer's optical drive. The disc will have been included with the Packard Bell computer.
2.Restart the computer with the disc inserted. A black screen will appear when the disc is detected, displaying "Press any key to boot from CD or DVD..." Press any key on the keyboard to launch the Windows installer. The "Install Windows" screen will appear.
3.Click "Next."
4.Select "I accept the license terms" and click "Next."
5.Click "Custom" when asked what type of installation you'd like. The other option is "Upgrade," but in order to restore your Packard Bell system to its factory settings, you must reformat the hard drive.
6.Click "Drive Options" when asked where to install Windows. Select the C: drive and click "Erase." Select the unallocated space after it has been erased, and click "Format." Format the space using the "NTFS" file system.
7.Click "Next" and Windows will begin reinstalling on the Packard Bell's hard drive. The system will reboot when finished and launch into your newly restored Packard Bell.
Sep 09, 2011 | Packard Bell W3301 Notebook
Packard bell itreme 1908 will not restore from maufactures disk
Rob: Do you mean compact disc, or diskette?
If it is a diskette ("Floppy"), there is a chance that the information on the diskette is fried and useless.
If, however, it is a CD? When was the last time you cleaned your CD drive? It does need to be cleaned, best once a month. The "cleaner" is actually a CD with tiny brushes on it that clean the optics in the CD drive.
The CD itself could also be fried (badly scratched, dirty, or even heat damaged).
Dec 02, 2008 | Packard Bell (ATXGM28AP)
Doesnt boot up
Hey, Blackchuck, try this
When you power up, try to get into BIOS and see what you get.
Let me know and we'll go from there.
Ron-
Nov 09, 2007 | Packard Bell Easy One Silver 2120 Notebook
Packard bell win 98
You need a floppy windows startup disk.
Nov 08, 2007 | Packard Bell Packard-Bell Full Page...
Packard Bell Laptop
Upgrade bios first...then load bios defaults in bios....solves most problems, if still no cd, borough one from friend,if still not....cd enclosure in side laptop faulty or broken...this happen if continous in and out sliding of cd. JJ
Sep 15, 2007 | Packard Bell Easy One Silver 2101 Notebook
Computers & Internet Logo
184 people viewed this question
Top Packard Bell Computers & Internet Experts
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
