Power light blinks red 7 times
SOURCE: sony sxrd kds-r69xbr1
4 red blinks indicates a fan error. usually blowing duster inside the fan blades will cure this. there are 4 fans inside this tv. looking from the back of the tv, the large fan on the left side is usually the culprit...good luck to ya
SOURCE: sony kds 50a2000 power light blinking
Your lamp has blown. You can order the lamp from Sony and replace it yourself. You can purchase the lamp here:
http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog
Other vendors also sell this lamp at a cheaper price (check the net)
SOURCE: replacing the exhaust fan on a KDS-R60XBR1
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
