Peg Perego John Deere Gator HPX Logo
A
Anonymous Posted on Apr 01, 2013
Valve adjustment 620i gator - Peg Perego John Deere Gator HPX
Adam Fjeld
Level 3:
Genius:
  • Peg Perego Master 1,508 Answers
  • Posted on Aug 18, 2017
Adam Fjeld
Peg Perego Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542690
Points
1761
This toy doesn't have a valve
2 Related Answers
adamfjeld
Adam Fjeld
  • 1508 Answers
  • Posted on Jun 08, 2012
SOURCE: 2005 John Deere Gator CS. Had valves adjusted in
this is the forum for the kids toy
adamfjeld
Adam Fjeld
  • 1508 Answers
  • Posted on Jun 14, 2012
SOURCE: how to replace CV Boot on JD
wrong forum
2answers
Gator 620i is back firing
fuel flow problem
use the choke more
clean out blocked main jet
shift problem.
https://watchonlinehub.com/online-watch-hindi-zero-2018-full-hd-movie-free-download.html
Dec 19, 2018 • Toys
I have a gator xuv 4x4 620i and it won"t start but makes a clunking sound instead
check starter bolts pull plug and do a compression test clunk in engine never good possible spun rod bearing
How do i adjust the throttle position switches on a john deere gator 620i
YOU DONT! Factory specs are need to test and set it!
First off what is the problem you are having????
All the TPS does is switch from one timing curve to the other on the cdi, and is also connected to the fuel management computer to tell it when to increase fuel delivery.
If you are having running problems start with old fuel, fuel pump pressure, and last if you have modified the airbox or exhaust in any way it will run like crap! On fuel injection you have to get a tunable fuel management computer when increasing air-flow or exhaust flow. The fuel injection is set from the factory based on the OEM parameters.
How many hours/ miles on your unit?
Have the valves been adjusted if it has over 200 hours of use?
are there any codes being flashed on display when key is turned to on position but not running?
How to remove the bolts on the starter John Deere Gator 620i
This is what I did to remove starter on 620i xuv gator. Remove starter solenoid and use extension 3/8 drive with universal joint to remove top bolt or remove front half of plastic shroud over drive belt assy , drill hole into cover in line with top starter bolt, insert extension with socket onto top starter bolt. Be sure to cover drilled hole with suitable material.
Jun 30, 2012 • John Toys
How do I open hood of john deere gator 620I 2008
the hood doesn't open on this toy but the front grill does flip down
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
