Sony DCR-TRV285E Digital-8 Digital Camcorder Logo
Question about Sony DCR-TRV285E Digital-8 Digital Camcorder
Tape stuck inside Sony VX2000
My husband is an eletronic engineer, he has my Sony VX2000 torn apart to try to get a mini DV tape out of the cassette drive but there literally are no screws or devices to open the cassette up to fix it. It's like a safe! How in the world do we get this tape out of there??
Posted by sheryl wardell on
jvsvisual
    New Friend:
  • 29 Answers
If you are on about the VX2000 which is similar to the professional DSR-PD150 remove battery or supply then simply apply 3volts to the main mech drive motor and unthread the mech from the load position you will notice if it is in the load position because tape will be laced around the drum assembly hence the fact you can not remove the tape
John www.jvsvisual.com
Posted on Apr 18, 2013
5 Related Answers
Anonymous
  • 36 Answers
SOURCE: Sony DCR TRV38
Good Day, you need to supply 4.5V DC regulated to the loading motor, however you should disconnect the connector from main board to loading motor, in order not to damage the driver IC. If your technically inclined, and you have the equipment, do it, if your not sure, just refer it to the nearest svc ctr. thanks
Posted on Sep 04, 2007
Anonymous
  • 4402 Answers
SOURCE: Tape stucked in the Sony DCR-PO101 NTSC Handycam
nope
Posted on Jan 21, 2008
Anonymous
SOURCE: cassette tape will not load
meow
Posted on Jun 12, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Sony Camcorder Mini DV tape doesn't go in
Have you cleaned the tape deck at all? That might work.
Posted on Jul 04, 2008
Anonymous
  • 6 Answers
there is a small motor at the lower right corner ( if you face the tape side of the camcorder). check if the motor reponds to a 5v voltage. if not, that is the problem
Posted on Sep 06, 2008
DSR-1800A DVcam TAPE EJECT ERROR 21
This error means the reel position motor is not moving the reels either together for mini DV or appart for large tapes. Usually because the sliders or gears have run out of lubrication and have seized due to not being serviced periodically. Otherwise there may be a foreign object stuck in there like a torn label etc.
Try a different size cassette tape, it may be ok on large if you are trying small or vice-versa, because it is already in that position.
Mini dv stuck in sony dcr-vx2000
Hi
I had that happen and read to take the battery out then plug it in to the wall and it worked. As soon as I did the tape came out.
Please try it and let me know.
Sep 09, 2008 • Cameras
I have a vx2000 and it has a flashing yellow box with what looks like a water droplet inside of it. Also where the amount of tape left would be there are numbers flashing. Whats wrong with it?
Sounds like the DEW warning is activated.
This occurs when you take a camera form a heated room to an external cold environment. Condensation forms inside the camera.
The Dew warning serves to protect the tape and camera. Wait until the camera acclimatizes and the condensation disappears.
There is most likely nothing wrong with the camera.
Tapes recommended for DCR-VX2000? Also, How long c...
only 30 sec and play a blank cassette for 30 min
if needed repete three times not more
20helpful
2answers
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
1helpful
2answers
Torn DV mini tape what do I do now?
I would go to a professional camera store like a Ritz and see if you can find splicing tape, yes they sell such a thing but it may be a bit hard to find, if you find it youll have to pick a point on either side of the damaged tape and cut it as cleanly as possible and apply the splicing tape, when played thecut out part will of course be missing and the tape may jump over that point a little but it should work.
3answers
Sony dsr-45 tape
It is:
Sony cleaning cassette DVM12CLD you can buy it from ebay at 15 pounds. click on the following link:
http://cgi.ebay.co.uk/Sony-DVM12CLD-MiniDV-cleaning-cassette-in-Blister-DVM12_W0QQitemZ370257959235QQcmdZViewItem
Removed mini dv tape, reinstalled mini dv tape... cassette wont close, all power lost!
internal power supply fault, unit needs to be checked by a panasonic technician.
Top Sony Video Cameras Experts
Marvin
Marvin
Jaime Hernandez
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
