Cameras Logo
Posted on Apr 02, 2013
Manual for Sunpak auto 121C - Sunpak Cameras
1 Related Answer
  • 102366 Answers
  • Posted on Feb 05, 2012
SOURCE: need user manual for Sunpak power Zoom 4000af
You may download a copy of the manual from here.
Does someone have a manual for the Sunpak Auto 355af thyristor flash?
Hey there,
I had one a couple of months back, but unfortunately I got rid of it since I no longer use it. But, you can certainly buy one online. Check out Amazon or Newegg.
I need a operating manual for Sunpak Auto Thyristor G4500DX Flash gun only
I found this for a Sunpak flash which is similar to the G4500dx:
Reading from the "auto555/G4500DX" Manual, you need to:
1. Slide the Film Selector to desired ISO - (that is the same as your camera ISO used - so, make sure you turn Off the Auto ISO feature if your camera has one).
2. Slide the Mode Selector to "A" (Auto position). This will be Auto Thyristor mode on the flash.
3. Slide the Auto F/stop Selecct Know to desired lens openning - ( so use your camera in Aperture priority mode, more in Manual to prevent changes in the camera aperture value during shooting)
Shoot, and be happy with well exposed pictures by the Auto Thyristor features of the Sunpak 555 flash.
The Sunpak 555 works great with Nikon D50, D70 cameras, as you can synchrinize flash practically at all shutter speeds. Excellent for sunny days to get narrow DOF, yet get any ambient light level contribution as desired.
For other cameras, make sure (watch out for) that Aperture Priority mode does not use shutter faster than the camera max X-sync speed - so Manual camera mode could be a better choice for a novice photographer.
In the manual there is also a list of accessories for various brand cameras, How to use Power Ratio in Manual mode, some advice on using wide lenses, how to care of your 555, and Specification section.
Minimal flash duration is 1/450 at full power, so you can safely use Auto Aperture up to 1/500 sec. Flash duration decreases with lower power setting, or lower auto mode need for poser, and the shortest flash duration is 1/17000th sec.
Sunpak Auto 422D Thyristor won't flash
It should work automatically once connected properly, in case it doesn't work something is not right, obviously. Did you try it out with a different camera? That could help you in figuring out the problem.
Nikon D5200 PDF Manual Download
2helpful
1helpful
Manual of sunpak auto 266 d flash
You may download a copy of the manual here.
1helpful
Need user manual for Sunpak power Zoom 4000af
How does the Sunpak Auto 555 Thyristor Flash Unit work concrning a battery? Does it always need the ourside battery pack unit also?
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
Flash
becRN,
take the camera to a good camera store and try any in your price range, the manual should state the camera's that are compatible. note that many new model flashes do not work on older camera's.
Top Sunpak Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
