2002 Ford Taurus Logo
Posted on Apr 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver door closed but door alarm and lock keep going off?
When hitting a bump the overhead light goes on and the open door alarm sounds
Roger Chapman
Level 2:
Novelist:
Scholar:
  • Ford Expert 150 Answers
  • Posted on Apr 02, 2013
Roger Chapman
Ford Expert
Level 2:
Novelist:
Scholar:
Answers
150
Questions
Helped
45576
Points
296
Sounds like the door latch is not closing all the way, Try spraying some WD40 into the latch in the door where it hits the striker post. Hold the door handle up and bump the door shut and open while holding the handle up on the out side several times, This should loosen the latch up and the door should close and latch. The more you spray and work the door the better it should get. If not the latching mechanisim may need replaced. I hope I have help you sovle the alarm problem.
5 Related Answers
Anonymous
  • 205 Answers
  • Posted on Mar 05, 2011
SOURCE: My door ajar light is on but all doors are closed
You have a bad door ajar switch on one of the doors. It is shorting out and causing the lights to flicker and the door ajar light to stay on.
Anonymous
  • Posted on Feb 01, 2009
SOURCE: door ajar light on
The drivers side door switch goes bad all the time on those, try replacing or check if its sticking.the small little button int the door jam.
Anonymous
  • 5158 Answers
  • Posted on Jan 09, 2009
SOURCE: 1999 Ford Expedition Interior overhead lights stay on, door locks
locate the relay for the interior lights and doorlocks and replace it.
Robert
Anonymous
  • Posted on May 18, 2009
SOURCE: door ajar light will not go off and all doors are closed
I had this problem. I had to have a sensor in the door replaced.
Anonymous
  • Posted on Jun 11, 2009
SOURCE: 2000 ford windstar - rear driver power door latch stuck in shut/locked position; can't close the door since latch won't open to latch closed
put a screwdriver in the latch jaws and force it open
I assume the factory alarm was somehow bypassed when they installed the remote start is there a way I can make the factory alarm work when the doors are opened without key,?
To arm content theft alarm.
1. Open the door.
2. Lock the door with the power door lock switch or
the remote keyless entry transmitter. The
SECURITY light should flash.
3. Close all doors. The SECURITY light should go off
after approximately 30 seconds. The alarm is not
armed until the SECURITY light goes off.
If a locked door is opened without the key or the remote keyless entry transmitter, the alarm will go off. The headlamps and parking lamps will flash for two minutes, and the horn will sound for 30 seconds, then will turn off to save the battery power.
2answers
Hyundai accent 5DR 2005 car alarm keeps going off..
It sounds to me all you need is to adjust the trunk hatch. Its going out when you hit the brakes so the switch isn't bad. It may be worn but if you can push on it and the light goes out it is the reason your alarm is going off. Make sure there isn't debris under the rubber seal preventing it from fully closing.
I replaced a battery in my 2001 pontiac montana n the lights started blinking as if the alarm was going off.i hit the unlock n lock button n the blinking stopped. i have power,lights n radio but van wont...
It can be any of the car doors not got properly locked or the door is locked but the switch is not sensing the door locked. Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.
And last thing alarm connections need to be inspected. It's getting short somewhere in between.
There are few help links with solutions, to troubleshoot these types of problems. I suggest going through these links.
Click the link below: ------
Volvo car alarm keeps going off for no reason
http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
Alarm keeps going OFF
http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
2009 Toyota Camry: Hood Switch causing Alarm to go OFF?
http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
Ford Pickup Alarm will not disengage?
http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
Mitsubishi Diamante: Factory Security Alarm will not go Off
http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
Toyota Avalon Factory Alarm will go off?
http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
Chevrolet Tahoe Hood open warning on dash and alarm sounds?
http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
These details will help.
Thanks.
2answers
Locks, Map Light(s) and alarm not working!
it sounds like you are having a problem with the ecm which is the electronic control module which is the BRAIN of your entire car. Also when this happens everything goes haywire as if the car is acting retarded because the ecm is not receiving the proper codes on how to perform and remember the ecm is a computer that could have corrosion or rust on the connection points. check this ok that might help.
Door ajar light and alarm comes on when the car is in motion.
dear friend-you need to adjust the door lock as it is not closing properly
2001 Jeep GC Laredo - Interior Lights stay on while driving
Sounds like a fuse issue. check your panel for popped accessory fuse.
the overhead light issue may be the door close switch
3helpful
2002 Honda Odyssey security alarm system
Make sure your hood is shut. I just got my 2002 Honda Odyssey back from the dealer today (90,000 mile check-up - I love my van and will drive it until it dies!) and when I went to lock the van with my remote transmitter, the lights didn't flash and the horn didn't sound. I open and closed all the doors and tailgate and I could hear that the doors were locked, but the security system wasn't working and that is why the lights didn't blink or the horn didn't sound. I walked up to the front of the van to check the hood to make sure it was closed (there isn't an indicator light for an open hood, only open doors) and the hood wasn't shut completely. Once I opened the hood and let it drop to securely shut, I hit the door lock button on the remote and everything worked like a charm! Hope this helps others in this predicament.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
